Old 8th December 2010, 10:28 AM   #1
clrs is offline clrs  Netherlands
Default Subwoofer with TB W5-1685
Dear all,
after building a pair of Lancetta's I am looking for a small sub to support them.
The idea is to build two small subwoofers with the Tangband W5-1685: click Is it possible? Or should I go for the W6-1139SG or W8-740 which are actually designed for subwoofer use?
First results with WINISD:
Vented box, volume~21 liters, tuning frequency~43 Hz, though I'm having some troubles with the group delay, which is too high.
Any suggestions?
Kind regards,
Coen
Old 8th December 2010, 01:48 PM   #2
I have no experience with the w-5, but yes I would seek a driver intended for sub duty. I built some tapped horns with the 1139 that perform well. I've also been tinkering in winisd with the 740, as I bought 2 for cheap on cyber monday. Sims are promising- 0.75ft3 sealed, factoring in 6db boost @ 30hz and a lowpass @ 80. I tried simulating ported but the driver specs call for such a long port it wouldn't be possible to fit a port in a modest sized cab.
Here's the sealed response.....
Old 8th December 2010, 08:14 PM   #3
W8 could be both vented and sealed. I read somewhere it could be 5 liters sealed or 10 liters vented (f3=41 Hz). Going to try this myself with WINISD. I will post some results soon.
Old 20th December 2010, 03:41 PM   #4
Decided to use a Tangband W69-1042 with following results:
Volume = 28,00 liters
f3 ~ 40 Hz
port length = 20.00 cm
port diameter = 6.8
both WinISD and the calculator from lautsprechershop.de gave the same results.
Old 20th December 2010, 05:22 PM   #5
gooki is offline gooki  New Zealand
Looks good.
TB W5-1611SA vs. MA Alpair7 barackuda Full Range 42 6th February 2011 11:57 PM
Tang Band W5-1685 BIB? geepee Full Range 5 16th August 2010 12:00 AM
Where can I buy a TB W5-1126SC? roadsterdriver Subwoofers 1 14th November 2009 05:48 PM
Anyone built a TB W5-1611 Horn? Herr_Mo Full Range 3 2nd July 2009 08:10 AM
tb w5-1685 as semi FR? brookbh Full Range 2 6th February 2009 04:33 PM
Page generated in 0.07812 seconds (72.24% PHP - 27.76% MySQL) with 11 queries
