Have 2 Fi Q18s - can I use them for PA subs? Have 2 Fi Q18s - can I use them for PA subs? - diyAudio
Old 5th December 2010, 12:57 AM   #1
ebr is offline ebr  United States
Default Have 2 Fi Q18s - can I use them for PA subs?
New here and have done some searching but can't find any specific answers and only one hit on my specific driver. So, if my question is obvious, I apoligize and ask that you simply point me in the right direction. Thanks.
I built a custom sub "wall" for my dedicated theater in my last house with 4 Fi Q18s. When I sold the house I took two of the drivers out and brought them with me. I am running sound now for a local amatuer band and we need some subs for kick and bass reinforcement. Can I use these drivers or am I better off with something else? If I can, what kind of design should I be looking at? We don't play huge venues obviously but we need something to give us that punch. Needs to be somewhat portable and easy to build .
Suggestions?
Old 5th December 2010, 03:59 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Those look a little too much like a home theater type sub. If you are looking for "punch" you will need to use a PA type woofer.
planet10 needs your help:
Let's help Ruth and Dave
Old 5th December 2010, 04:12 PM   #3
Thanks for the reply. Fi, I think, specializes actually in car woofers but I did have these made for my HT install. I found the specs from when they made them:
Re 2.8 Ohms
Fs 22.0 Hz
Qms 5.44
Qes .56
Qts .51
Mms 345
Cms 1.52X10^-4 m/N
Vas 310.2 l
SD 1210 cm^2
Bl 15.41
SPL 89.6 1W/1m
What kind of specs should I be looking for?
Old 5th December 2010, 04:32 PM   #4
Speakerholic
Cal Weldon's Avatar
Things like these:
18 INCH PROFESSIONAL DRIVERS | Parts-Express.com
Eminence Replacement Speakers, Eminence Woofers, Eminence Raw Drivers, Eminence Guitar Speakers With Free Shipping!
There's some Selenium, Dayton and Eminence to look at. There's lots more on the site.
Old 5th December 2010, 08:09 PM   #5
Thanks. If you don't mind one more question - what would be the simplest high-impact PA sub design? I would imagine sealed is simplest but will that produce the punch I'm looking for?
Old 5th December 2010, 08:13 PM   #6
Speakerholic
Cal Weldon's Avatar
I think you'll find most standard PA type boxes are ported or horn loaded. Usually ported will be easier to handle but horn loaded most often gives you best bang for the buck. Some manufacturers have cabinets plans available for their product.
Old 5th December 2010, 08:19 PM   #7
gripracer is offline gripracer  United States
Banned
what's wrong with the Fis for PA bass use? don't you just need to move air? It seems like the Fi's would have a higher ability to move air than a PA woofer.
Old 5th December 2010, 10:27 PM   #8
18Hurts is offline 18Hurts  United States
You could use them,
It will take a LOT of power to get high sound pressure levels though. Generally speaking, PA speakers have very light weight cones and a shorter stroke since they tend to cut off at 35 to 45 Hz. The light weight gives much higher sound pressure levels in the "music band" or around 40 Hz.
Back in my PA days, I ran Cerwin Vega W15P woofers that had a sensitivity when tuned to 40Hz (SPL 1 watt/1 meter) of 100 dB. They would punch out over 120 dB with the rest of the box at 100 to 200 watts with ease.
If you slapped those Fi subs in a sealed box (what the numbers indicate you should do...look at the Qts of .51) it will be a HUGE box and you'll need 1000 watts to get 120 dB. Run two of them and that is 2,000 watts and blown breakers all around.
You could model them ported at 30 to 35 Hz and see what you get or maybe they can be horn loaded? The horn loading will give you at least a 8 dB boost in sensitivity so that might be your best bet. They will be BIG though... maybe if you tuned them for 35Hz to get the horn loaded box down to a manageable size?
Since the Fi subs seem to prefer sealed boxes--would the "scoop" style subwoofer design be his best bet? There is a solution out there--it might be rather large/heavy but something should work.
Old 6th December 2010, 12:25 AM   #9
HaoDaMao is offline HaoDaMao
PA "punch" is about 80-160 Hz output. PA subs rarely dip below 50 Hz; it's just not used in live sound. So you want a sub capable of a LOT of output in what most car guys call the midbass area - the impact of a kick drum frequency range.
To get a good amount of stroke, you need high efficiency or LOTS of power. Lots of power is an option if you have dedicated wiring; otherwise you're pretty much limited to ~1500W (in the US) for your subwoofers (one, typical 15A circuit), and a low efficiency 18" with 1500W will simply not have the stroke or output in the 100-200 Hz range than a high efficiency subwoofer will.
The Qs, like most car and home audio subwoofers, excel at the first octave (20-40 Hz) stuff that simply doesn't matter for prosound use.
Old 6th December 2010, 12:52 AM   #10
Yeah, these things were designed for an IB or large sealed enclosure, so I understand the mismatch. I imagine the size of the box and amount of power needed for them will make them unmanageble. I'll keep them for a better use. Thanks everyone for the input.
Have 2 Fi Q18s - can I use them for PA subs?Hide this!Advertise here!
The old PA vs HI FI loudspeaker debate again.... Village Plank PA Systems 42 9th May 2010 11:18 PM
PreAmp and Equalizer for Hi-Fi, PA Inductor Solid State 4 8th August 2009 12:57 PM
PA subs using Omega Pro 18's soulfinger Subwoofers 4 28th July 2007 02:03 AM
what do i need to built PA Subs? Moonfu Subwoofers 16 9th September 2004 12:38 PM
12 inch subs for pa! Bull Subwoofers 11 5th May 2004 10:31 AM
Copyright ©1999-2017 diyAudio
