Old 4th December 2010, 04:29 AM   #11
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Originally Posted by jbell View Post
shameless plug for one of mikes designs -- sounds like it's exactly what you are looking for.
Reed Exodus Anarchy 25hz Tapped Horn - AVS Forum
It feels oddly sacrilegious correcting jbell on tapped horn matters, since much I know about TH's and other tapped resonators I learned from him.
However, as the OP already stated, I don't think this design will be good up to 200Hz (quite a high xover imo... is it a small fullranger on top?).
In my experience a TH will cover about 2 octaves. So, depending on how low you want to get, a TH might still be a reasonable option. Will only get down to 50Hz though.
At what frequency are you thinking about crossing over to your corner subwoofer? Or do you intend to run the bass bins all the way down, with additional subwoofer?
Regards, James
Old 4th December 2010, 12:59 PM   #12
jbell is offline jbell  United States
Here's mike's 2pi measurements. Yea it's not ruler smooth from 100-200, but with a 150 cross on the sub to tame the 150-200 peak, and a 200cross on the tops, should be very acceptable.
A tower with 4 mcm 55-2421 would also be a cheap option, although not ruler flat to 30 hz like mikes design....
Old 4th December 2010, 04:39 PM   #13
I plan to run the bass bins with active crossover around 200hz to make my stereo pair full range. Corner sub is to add low effects only for HT
Not totally satisfied with the bass from my standmount speakers which are otherwise wonderfull, So I'm making them 3 way
Right now I am just running them as small and using my HT reciever to crossover to a pair of home brewed mono subs under the standmounts but the current subs are based on 2-12's with 15" wide cabinets and are not found to be attractive, hence the mandate to build something no wider than my standmounts
I own all the amps and crossovers so just need to pick the best 8" woofers
Old 5th December 2010, 01:43 AM   #14
Are you standmounts exactly 9 inches wide? From a proportion and aesthetic point of view, the bass bins should be slightly wider than the width of the speakers sitting on them, to give a good proportion of larger base and stability. Unless you are shooting for a parallel sides look where everything is the same width from the top to bottom. Would also gives you a bit more volume to work with for the bass bins.
Old 6th December 2010, 11:11 PM   #15
Any thoughts on the Newer Scanspeak Discovery series they show an 8" woofer that is affordable ?
https://www.madisound.com/store/prod...oducts_id=8772
Old 7th December 2010, 12:18 AM   #16
Or the 8" SLS at PE ?
Peerless 830667 8" Paper Cone SLS Subwoofer | Parts-Express.com
Bass bins for 12" drivers Frode Multi-Way 6 8th November 2010 02:29 PM
Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? IG81 Multi-Way 3 4th February 2010 02:48 AM
How to make Bass bins Jaminator Subwoofers 8 8th November 2007 11:24 PM
Dalesford Bass Driver - Any suggestions for a replacement? MCH786 Multi-Way 2 1st January 2007 03:25 PM
Dual driver box suggestions needed nu2bass Car Audio 8 20th September 2005 11:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
