C/E/X PA Flat to 30 (FT30) PA TH Awesomeness
Old 15th May 2012, 02:58 AM   #751
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Eminence will do pretty much whatever you want if you pay for tooling and order 5000 pieces...
Dan
Old 15th May 2012, 08:28 AM   #752
djk is offline djk
djk's Avatar
I have purchased from them before. A custom 12 with a 0.3125 top plate, 2" coil, and a 54 oz magnet. And two different 15 models, both with 0.375 top plates, one with a 2-1/2" coil and 54oz, the other with a 3" coil and 95oz (PA stuff).
Candidates for the Darwin Award should not read this author.
Old 15th May 2012, 03:27 PM   #753
Djim is offline Djim  Netherlands
Originally Posted by djk View Post
I talked to Eminence a while back about making a custom driver with a ferrite magnet, three inch coil, heavy cone, 10mm x-max, Kappa Pro 15LF type magnet structure. It's do-able.
Hi Djk,
That looks like an old RCF L15P200 (the AK version has a 4 inch coil)
Old 5th June 2012, 03:28 AM   #754
kctess5 is offline kctess5  United States
What drivers will work with this that are a bit cheaper than the $300 (when bought in groups of 4) 18TBX100? I will model a few but I don't know if someone already has a list
Old 5th June 2012, 03:59 AM   #755
B&C 18PS76 18" Woofer 294-675
This models very well, and it's $100 cheaper. It's got a little less x-max at 7mm but thats pretty much all I will be able to push it to with under 300w of power per speaker.
Old 7th June 2012, 12:30 PM   #756
epa is offline epa  Netherlands
i gues it depends on the power availeble.
with enough power the tbx wil be better.
with limited power and funds, the ps would be a good choice.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 21st March 2013, 05:33 AM   #757
m R g S r is offline m R g S r  United States
Cone seems very light. Don't know how strong it will be loaded in a horn....
Old 21st March 2013, 06:54 PM   #758
Hi mRgSr,
Can you give one example where cone failure happened with an Italian brand driver without overpowering it?
In other words, the whole light cone argument that could lead to mechanical failure, is a non issue for pro LF drivers.
Old 21st March 2013, 07:22 PM   #759
What I meant was strong with output. It may sound fine at low power, but drive it to its AES rating and it may not sound so good. Many on here have commented on tapped horns with light cones and uneven loading sounding distressed at higher output...
But didn't Tom Danley say a while back, how he had to create a glass window in the side of a cabinet in order to see what was going on (with repeated cone failures) and when a certain frequency was hit, the cone would fold up....
Old 21st March 2013, 07:41 PM   #760
Hi mRgSr,
The 18PS76 does not have an extended Xmax nor extreme power ratings but has a relative strong motor. As long you don't try to push it beyond Xmax with brute force I don't see any problem.
Do you have a link of that Danley quote?
C/E/X PA Flat to 30 (FT30) PA TH AwesomenessHide this!Advertise here!
Nakamichi PA-5 and PA-7 Design Help Requested Apogee Pass Labs 20 30th May 2013 04:54 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 01:37 PM
Vintage Peavey PA-120 Transistor PA amp ElectricMan Swap Meet 2 26th May 2010 06:22 PM
Nakamichi PA-7 and PA-5 amps Redwingnine Pass Labs 11 30th April 2010 10:27 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 08:54 PM
