C/E/X PA Flat to 30 (FT30) PA TH Awesomeness
Old 7th January 2012, 12:45 AM   #501
Djim is offline Djim  Netherlands
That is for two drivers per cab???
Old 7th January 2012, 01:22 AM   #502
CRESCENDO is offline CRESCENDO  United States
Not to my knowledge. Does something in the HR screen suggest this? Maybe I missed something (very possible).
Old 7th January 2012, 01:34 AM   #503
Look at TH value, it says 2P (2 drivers in parallel) and under that you see 2 x SD. Besides that, these are the parameters of the old version of the 3015lf... But at least you understand my first question now and that it becomes a little foggy.
Old 7th January 2012, 02:28 AM   #504
OMG! I was unaware that driver arrangement doesn't reset to "1" when creating a new enclosure. I bet it's due to pressing "add" after a PPSL design I modeled. My apologies. Now I must go back to readjust parameters. The response I was getting looked too good to pass up. Now I know why
Here's what Eric gave me to work with. The driver parameters are different from both old & new spec sheets I have. He suggested S values to range from 1000-1500.
ID=28.00
Ang=2.0 x Pi
Eg=44.72
Rg=0.00
Fta=0.00
S1=1100.00
S2=1100.00
Par=0.10
F12=0.00
S2=1100.00
S3=1100.00
Par=0.10
F23=0.00
S3=1100.00
S4=1100.00
Par=220.00
F34=0.00
S4=1100.00
S5=1100.00
Par=20.00
F45=0.00
Sd=881.10
Bl=17.00
Cms=1.36E-04
Rms=2.99
Mmd=82.73
Le=1.87
Re=5.50
TH=1
Vrc=0.00
Lrc=0.00
Ap1=0.00
Lpt=0.00
Vtc=4000.00
Atc=880.00
Pmax=100
Xmax=5.0
Old 7th January 2012, 09:18 AM   #505
epa is offline epa  Netherlands
correct.
a straigt pipe ranging from 1100 to 1500 cm2
@ 1500 giving the most eff,down low,but also more group delay there.1 drvr a cab.
i simmed both boxes and as expected there is not much difference ,the symetric model 1 having +.5db on 35 hz and the standart model 2 having + 1 db in the midle area.
i prefer the model 1 because i think the cone wil be symetricly stressed(remember 4pyros probs)
but bot wil work fine,especialy corner loaded.
about the ts ,1 or 2 parameters must be of i think its sd and/or bl. but it doesnt make much difference in the sim.
grtz erik
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 7th January 2012, 11:43 AM   #506
4pyros is offline 4pyros
Someday this winter I will fix that.
Old 7th January 2012, 06:15 PM   #507
Hi Crescendo and Epa,
Maybe it's an idea to enlarge the mouth to 4000cm^2 (or as large as the total front of the cab). The little loss at low end in favour for a gain of 2dB overall is something I should consider. In max SPL there is even more to gain than 2dB because the excursion lowers also with a 4000cm^2 mouth. The excursion max transfers from 44Hz to 50Hz (remember Fs of the driver is 44Hz) and the group delay imporves slightly. All in all that means significant less stress for the driver.
Old 7th January 2012, 06:35 PM   #508
Old 8th January 2012, 12:21 AM   #509
I might as well build epa's tbx box or Xoc1's 6 fold and load them w/3015LFs with an adapter ring until I have sufficient funds to purchase the proper 18" drivers. The 3015LF seems to model not so bad in either enclosure. Does the delay look a bit odd? What do you think?
Old 8th January 2012, 12:48 AM   #510
Wouldn't worry about the delays too much but so far nobody showed me any SPL measurement that proved the 3015lf is capable of controlled excursion more than 8.0mm (that was 8mm with high pwr compression figures).
C/E/X PA Flat to 30 (FT30) PA TH AwesomenessHide this!Advertise here!
Nakamichi PA-5 and PA-7 Design Help Requested Apogee Pass Labs 20 30th May 2013 03:54 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
Vintage Peavey PA-120 Transistor PA amp ElectricMan Swap Meet 2 26th May 2010 05:22 PM
Nakamichi PA-7 and PA-5 amps Redwingnine Pass Labs 11 30th April 2010 09:27 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
