C/E/X PA Flat to 30 (FT30) PA TH Awesomeness
Old 29th November 2010, 03:32 PM   #11
epa is offline epa  Netherlands
does it need to go flat to 30 with 1 speaker ,2 or more per side?
this makes a big difference.
i woulden't be wise to give up spl for something you dont need.
i agree with 30 hz f3(i like the real lows 2) ,when you use 2 or more it wil be flat until 30 .
also would you post a bit of music (low notes).you want 2 reproduce.
i like 2 examen that.
in woody,s topic i posted a sample of a real low c synt. that was 32 hz centre freq.
Old 29th November 2010, 04:08 PM   #12
if you take Xoc1.m design 4 per side ,your goal is reeched
@900 watts x-max is 16mm 140 db @30 hz
Old 29th November 2010, 10:01 PM   #13
CRESCENDO is offline CRESCENDO  United States
Flat to 30 from 2 would be ideal, but realistic?
That looks beautiful but, is that 4 per side or 4 total???
Here's some material to scan: DeepDub.zip
Only 1 file is 192, the rest are 320. Wish I had .wav or flac to send you.
Justin
Old 29th November 2010, 10:44 PM   #14
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
I suppose that the overall limitation would be what size events you are trying to cater for. Four of the large cabinets in a row would be impressive if your prepared to transport that volume of speakers. There might be a problem with bass steeriing if 4 cabs are lined up. J Bell has commented on using delays on the outer speakers with 4 of his big TH cabs to widen the soundfield.
http://www.diyaudio.com/forums/subwo...e-sound-2.html
Problems arise when the upper freqency wavelengths are smaller than the width of the cabinets. Without processing mid bass beaming is the result!
Are you planning on using a DSP such as a DCX2496 or a Driverack?
Old 30th November 2010, 01:11 AM   #15
Right now, I feel the only thing limiting me to do larger shows is lack of sound. I currently do shows for a few hundred people and they all want their clothing and nose hairs to vibrate.
SUVs and trucks I have used are typically ~48" wide and fit 2 Titan 48s side by side (24" wide/ea).
Yes, I currently use the DR260
Old 30th November 2010, 02:11 AM   #16
hellonwheels is offline hellonwheels
I think you should seriously look into 40 to 120... you give up both SPL and space fast after that.
Old 30th November 2010, 02:59 AM   #17
I'll wait til epa scans the tracks I sent him before I change my entire plan of action
Old 30th November 2010, 04:06 PM   #18
here you go
couldnt scan one track,il try that later.
imo go with 30 hz since 32 hz is the lowest (repeaded) sound u want to reproduce.
you can get that with 2 per side at the cost of some spl
Old 30th November 2010, 04:16 PM   #19
this can be dealth with by using an inverted arc.
justin is going to cross @ 100 hz max(3.4mtr wave length) therefore ,4 or less shouldn't be a problem imo.
Old 30th November 2010, 07:06 PM   #20
Thanks for running those scans. As we can see, 30Hz reproduction would be valuable in my case.
Also, I further see the value in high efficiency designs, even if a single cab doesn't grab the low end - your Xoc1.m sample above proves it's flat to 30Hz w/4 cabs
What program are you using to scan the files?
C/E/X PA Flat to 30 (FT30) PA TH AwesomenessHide this!Advertise here!
Nakamichi PA-5 and PA-7 Design Help Requested Apogee Pass Labs 20 30th May 2013 03:54 PM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
Vintage Peavey PA-120 Transistor PA amp ElectricMan Swap Meet 2 26th May 2010 05:22 PM
Nakamichi PA-7 and PA-5 amps Redwingnine Pass Labs 11 30th April 2010 09:27 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
