#661 | |
the dip above the pasband is due to the big vtc. i like to see the outcome
one good thing about music ,when it hit you feel no pain. so hit me with music.
#662 |
#663 |
So the owner of this design is real busy at this time.
Can anyone help me out with this design I would like to build one and I do not know akabak Thanks
Countryman skank Last edited by olsound; 23rd March 2012 at 01:44 PM. |
#664 |
hi stan
have you seen the latest revolution. of this ?
#665 | |
Countryman skank |
#666 |
Speakers I have mind for this project are
18 sound 18wl2400 used B&c 18tbx100 used B&C 18tbx100 new
Countryman skank |
#667 |
first it must be put in akabak,even then i dont know how to aproach the pathlenghts.
easyest way is to make a test box ,measure it,and adjust the lenghts from there.
#668 | |
Maybe Martin can drop by on his lunch break if he have anytime to spare and tell us how to approach the pathlenght for this TH, are maybe someone else can help us out. Thanks
Countryman skank Last edited by olsound; 26th March 2012 at 02:34 PM. |
#669 |
Concider this end condition. The panel is extended right to the back for half its width. This gives a single defined path for the horn. The size of the cutout can be adjusted, and should give an area for the corner turn that is equal to or bigger than the area of the previous section.
#670 | |
Thank you for help again this design is crazy yet it look easy to build
Countryman skank |
| Nakamichi PA-5 and PA-7 Design Help Requested | Apogee | Pass Labs | 15 | 6th February 2013 05:12 AM |
| Nakamichi PA-7 & PA-5 Bias Setting? | sourceoneaudio | Solid State | 6 | 8th March 2012 12:37 PM |
| Vintage Peavey PA-120 Transistor PA amp | ElectricMan | Swap Meet | 2 | 26th May 2010 05:22 PM |
| Nakamichi PA-7 and PA-5 amps | Redwingnine | Pass Labs | 11 | 30th April 2010 09:27 PM |
| 5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? | jm_kzo | Multi-Way | 54 | 22nd April 2009 07:54 PM |
