Old 14th March 2012, 06:01 PM   #651
epa is online now epa  Netherlands
seeing it now it shouldnt be a problem.
it looks closer in post 648.
nice approach btw
one good thing about music ,when it hit you feel no pain.
so hit me with music
Old 16th March 2012, 01:35 AM   #652
grec13 is offline grec13  Russian Federation
Originally Posted by Thawach View Post
beautiful lady! epa new tapped horns are beautiful more than the past. i just hv designed as the same. love tapped horn with the sound but hate it when have the the problem when bend it. i try to design push pull tapped horn like this but still can't finish. i hope will finish if not i will want ur help with my desu\ign. thanks 4 the pic friend.
Wow! That PP idea looks nice too! How low you want to tune it?
sergey
Old 17th March 2012, 08:16 AM   #653
conical rectangular th(credits to Xco1)
Old 17th March 2012, 11:57 AM   #654
I am in love with this box conical rectangular th(credits to Xco1) This is the coolest TH design.
Which speaker this design use.
it also looks easy to build.
Can i have it.
Pleaseeeeeeeeeeeeeeeeeeee
Old 17th March 2012, 03:06 PM   #655
Very impressive guys!
What are the dimensions?
What is the knee?
What driver was used to model?
Great execution on a concept!
Larry
Old 17th March 2012, 03:08 PM   #656
hi stanley
its only a model.im gona bild this next time(test box),but it should work with most modern pro 18 inches qts 30 to 40 and vas 175 to 300 ltr.
now the folow up on this design.
i finaly had time to do some measurements.
here are the results
measured with uncalibrated beringer mic.
use arta and limp sw.
indoors close mic.
as we can see the horn is in reality shorter then simmed.
i used the white line ,but i think i should measure the red line.
in the hr sim the grey line is like the white line in the model ,and the red line in hr sim is what ive measured looking /comparing the imp graph.
it sounds good but not a flat to 30 sub(more flat to 40).
btw the shopped off first imp peak is due to either the sw or the elcheapo external usb soundcart i used.
edit/ this box was not designed for the 18sound lw 1400,but i had this one close by
Old 17th March 2012, 03:28 PM   #657
Thawach is offline Thawach  Thailand
Thawach's Avatar
nice approach btw
adjust a little, try to draw the drivers with the real scale. okay make me satisfy.
Old 17th March 2012, 03:32 PM   #658
Eric
That is a nice looking box you have there.
Old 17th March 2012, 03:34 PM   #659
Default cool
One more cool Th design.
Old 17th March 2012, 03:36 PM   #660
Thawach's Avatar
i only tune down to 40 hz. its near the fs of the driver. this's the graph respond. ill post the plan dimension when its finish to build in the next time. thanks
Nakamichi PA-5 and PA-7 Design Help Requested Apogee Pass Labs 16 23rd May 2013 10:43 AM
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
Vintage Peavey PA-120 Transistor PA amp ElectricMan Swap Meet 2 26th May 2010 05:22 PM
Nakamichi PA-7 and PA-5 amps Redwingnine Pass Labs 11 30th April 2010 09:27 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
Copyright ©1999-2013 diyAudio
