A Thread for those interested in PPSL enclosures - Page 43 - diyAudio
Old 13th February 2013, 08:25 PM   #421
djk is offline djk
djk's Avatar
Hey, I built two sets of that layout as double 18s about 20 years ago.
The first set were tuned to 38hz for PA work and worked swell to the 250hz crossover point. The second set were 6th order tuned to 28hz and after destroying two sets of drivers (the magnets came loose on the first set and started 'clanking') were re-tuned to 40hz.
Candidates for the Darwin Award should not read this author.
Old 13th February 2013, 08:40 PM   #422
epa is offline epa  Netherlands
Originally Posted by kees52 View Post
I have the wsp 26s woofers I did want to build this box for home theatre, but always I get to long pipes, because the woofers has low FS of 19 hz, but do the slot trow down the speaker fs and rise the qts yes or no, because some people way it stays the same, I have then need to measure in a slot alone to see what happens, or we make a small slot facing the speakers like in a ripole and look what happens.
the thiele small of this speakers.
maybe you can try them for me in HR, thanks, nut the box get really big, I do use basbox pro to test a normal vented box, and it go low but so long a pipe..
Rated power 110 Watt
Maximum power 140 Watt
Nominal impedance Z 8 Ohm
Frequency response fc - 7000 Hz
Mean sound pressure level 91 dB (1 W/1 m)
Excursion limit 22 mm
Resonance frequency fs 19 Hz
Magnetic induction 1 Tesla
Magnetic flux 1250 µ Weber
Height of front pole-plate 8 mm
Voice coil diameter 5 cm
Height of winding 1,45 cm
Cutout diameter 23,3 cm
Net weight 2,5 kg
D.C. resistance Rdc 5,7 Ohm
Mechanical Q factor Qms 3,19
Electrical Q factor Qes 0,38
Total Q factor Qts 0,34
Equivalent volume Vas 230 l
Effective piston area Sd 330 cm2
Dynamically moved mass Mms 42 g
Force factor Bxl 8,7 T · m
Inductance of the voice coil L 1,2 mH
i wil give it a go tomorrow
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 13th February 2013, 09:02 PM   #423
kees52 is offline kees52  Netherlands
Epa
Thanks, have a nice night.
dank je vanuit de rimboe, ja die zijn er ook in nederland.
vrg kees
Old 14th February 2013, 08:39 AM   #424
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
That is the Visaton 10" - no longer available
WSP 26 S 8 OHM
AINOgradient speaker project
Old 14th February 2013, 12:25 PM   #425
WSP 26 S 8 OHM
Yes I now but I have them, and so I do testing with it.
I have also seen mivoc speakers looks good and not expensive.
Strassacker: Speaker Building, Components
Old 14th February 2013, 12:42 PM   #426
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
cool thread, great
Old 14th February 2013, 03:06 PM   #427
@ kees
what bandwidth and volume?
. hr driver db
Old 14th February 2013, 03:41 PM   #428
Hi Epa
I like small, and bandwith is for say 20 to 150 Hz, I will go over around 100 Hz.
make it so volume is not to big, but I think this is difficult with 20 Hz, I say try the best
you can, I have hornresp and now a little how to work with it maybe you can help some with this.
I have now here the plenum alone where I want to measure the two woofers in it but why not use a plenum a la ripole who conusses face eacht other the magnet structure is both in the box, I have that not seen yet and maybe it works better for home theatre use.
thanks
kees
Old 14th February 2013, 06:04 PM   #429
its diffecult to get this driver to play low.
250 lts tuned at 20 hz .not verry small
if you punch the numbers from in the input screen,you cam play with the wizzard yourself.
click on the pic left bottom x to enlarge pic.
. hr driver db
Old 14th February 2013, 06:05 PM   #430
I have made a picture of the slot, I presume this is what is needed, the speaker is so tight that it can not though the sleeve but one panel has to be removed.
PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread. Spasticteapot Multi-Way 3 8th January 2007 05:35 AM
Might be interested in this distortion thread mashaffer Tubes / Valves 9 14th July 2004 01:08 PM
Interested ??? P901 Multi-Way 1 3rd December 2003 03:37 AM
Copyright ©1999-2017 diyAudio
