A Thread for those interested in PPSL enclosures - Page 39 - diyAudio
Old 6th November 2012, 01:17 PM   #381
sunnysal's Avatar
Default any thoughts on this driver for PPSL application
I saw this driver and thought its shape would lend itself to a nice PPSL build based on DJK´s design. thoughts on how appropriate it would be? what key dimensions I would need to assure function? I am only interested in response below 100-150hz (getting down as low as 20hz if possible) to mate with my Klipschorn based system.
http://www.tb-speaker.com/detail/1208_03/w8q-1071f.htm
Jean-Francois Lessard PP 2A3 Amp, Marantz 7T Preamp, 1993 Klipschorns w ALK xovers, Asus netbook, Squeezebox Touch, MSB link DACIII, MSB digital director, Audioquest Diamondback ICs, Synergistic Research Alpha Quad Active speaker cable
Old 6th November 2012, 01:47 PM   #382
tb46 is offline tb46  United States
Hi sunnysal,
I think that one is discontinued? (Otherwise a nice driver.)
Oliver
Old 6th November 2012, 02:19 PM   #383
sunnysal's Avatar
Originally Posted by tb46 View Post
Hi sunnysal,
maybe this one? W69-1042J, a little smaller and doesnt go quite as low (35hz free air) but...
http://www.tb-speaker.com/detail/1208_03/w69-1042j.htm
Old 11th November 2012, 02:42 PM   #384
Would it be worth trying KEF B139s in PPSL?
Neil
Old 21st November 2012, 07:54 PM   #385
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
I'm joining in here too. I was just tempted to make use of a 450L cabinet and put two 15" woofers in it. Norman guided me to PPSL which principle I already knew. Here is my latest plan, drivers will be the very cheap Dayton DCS380-4 an two 220-230L closed boxes opposed to make a slot. Yes the system will be 220cm wide! (8ft)
I plan to start makin cabinets soon but I can (if I can ) buy the drivers only after Christmas
AINOgradient speaker project
Old 22nd November 2012, 01:22 AM   #386
norman bates's Avatar
I assume you'll have 1 magnet hanging out and the other magnet in the enclosure.
Also, have both of the drivers share the same volume.
Sealed 8ft3 (qtc .707) each for that driver making F3 = 32.4hz.
Should do fine.
It would be neat to do a shootout of sealed F3 = 30hz compared to a ported F3 = tuned = 27hz. I'd imagine one would sound cleaner and louder but the other would go deeper.
Looks like a good driver for the money.
Old 22nd November 2012, 07:03 AM   #387
Juhazi's Avatar
Norman,
it's very difficult to make a connection between the two boxes because of the max. space available. Would a 100mm sewerpipe be enough?, I could put that in the lower corner in the slot behind elements. The backside corners should be covered/rounded anyway.
PP arrangement is easy here, only problem I see is that these drivers have a stamped steel frame that is not optimal. On the other hand it's easy to make a tight plenum.
Is it wise to make the opening of plenum 1/3 of total Sd like Nelson Pass did for his ppsl dipole?
I'm after clean and snappy (sub)bass mainly for music and I have MINIMUM 400L of cabinet volume to use. And MINIMAL budget. A tappeded horn is an option but I'm afraid of making it really well tuned. PPSL looks very promising and I'll go that way this time.
Old 22nd November 2012, 05:48 PM   #388
the narrower the plenum, the higher in frequency it works. Nelson got some boost with narrow slot.
It will be cleaner.
My dual 12's push pull slot loaded 27hz tune ported was cleaner, punchier, and faster than my buddy's 3 x jl audio 10" sealed.
Too bad the drivers can't share a box.
But good luck.
Old 22nd November 2012, 06:06 PM   #389
Juhazi's Avatar
Google Sketches of boxes, to get the idea of making the ppsl plenum
Left side with the plenum filling, chamber-connecting tube and driver magnet out.
Right side with the driver magnet in
Hey, if I some day have the money for two RSS390, I could make this to two vented boxes using the openings for pipe as throats of reflex tubes! Honestly, I am sure that the closed one satisfies my spl needs for some time
(don't pay attention to precise matching, this is a novice's quick sketch!)
Old 22nd November 2012, 09:55 PM   #390
djk is offline djk
djk's Avatar
That looks like a good solution, the chamber-connecting tube need only carry the difference in pressure between the two boxes, should work fine.
Candidates for the Darwin Award should not read this author.
PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread. Spasticteapot Multi-Way 3 8th January 2007 05:35 AM
Might be interested in this distortion thread mashaffer Tubes / Valves 9 14th July 2004 01:08 PM
Interested ??? P901 Multi-Way 1 3rd December 2003 03:37 AM
Copyright ©1999-2017 diyAudio
