#331 |
Opening is 1:2 of woofer's SD. These were made strictly for mid-bass. The dynamic impact is incredible! In the first picture you can see how the plenum is angled back. If I ever do another build, it will be that of a classic, shared volume, 6th order for SUB-woofer use only. I've come to the conclusion the ppsl is best utilized in the low bass only. The system in the picture uses them to 250 Hz, but my ears tell me 180 Hz and lower for best sonic quality. OR, it may just be inherint limitations of the drivers I used: Eminence 4012HO.
#332 |
Scott: have you tried them with a plenum which is as small physically as possible and no taper as shown in your first picture? Are your sections of sono tube sealed or are they vented? Thanks. Best regards Moray James.
moray james |
#333 |
Hi There
If I want to make a ppsl for this speakers, how to begin designing them and with what software this is possible. visatons 10 inch polypropulene Technical Data: Rated power 110 Watt Maximum power 140 Watt Nominal impedance Z 8 Ohm Frequency response fc - 7000 Hz Mean sound pressure level 91 dB (1 W/1 m) Excursion limit 22 mm Resonance frequency fs 19 Hz Magnetic induction 1 Tesla Magnetic flux 1250 µ Weber Height of front pole-plate 8 mm Voice coil diameter 5 cm Height of winding 1,45 cm Cutout diameter 23,3 cm Net weight 2,5 kg D.C. resistance Rdc 5,7 Ohm Mechanical Q factor Qms 3,19 Electrical Q factor Qes 0,38 Total Q factor Qts 0,34 Equivalent volume Vas 230 l Effective piston area Sd 330 cm2 Dynamically moved mass Mms 42 g Force factor Bxl 8,7 T · m Inductance of the voice coil L 1,2 mH thanks |
#334 |
Design for your speakers as you would any bass reflex cabinet, reduce the volume taken up by the plenum (slot) from the cabinet volume when calculating box size.
#335 |
Forgot to answer the second part of kees52 question, Hornresp is a good free software design program, it even allows the plenum to be considered as a stubby "horn" so you can determine what frequency it will cause a resonance at.
#336 |
Hi there
Thanks, I now hornresp and have done tapped horns with it, I have to play with it again. I have now the visatons in a acoustic resistance box where she doe very well there job, but as every audio freak we want to test everything ;-). Designing amps is mare my thing but she need speakers and this is a little a start for me, ready made are very expensive sometimes, and with diy I can save a lot of mony. The visatons did also very well in a H frame, I had very deep bas, I did really like it but it has to be located in the middle of the room for best bass, and bass was there only when present in music, that is like it has to be, so clean, normal boxes have sometime bas what is not in the music, (booming), that is what I don,t want. But we discuss here the PPSL. Oke, PS plenum? (slot) my english is not that good, is this the space between the two speakers, opening, maybe a picture will help, I see these have efficienty like horns? because you are use horn for mid and high. I go read google for more about it, it looks also like a OB dipole woofer woho has not so high efficienty. Dipole Woofer And here discussing about to use hornresp. Hornresp thanks again Last edited by kees52; 4th October 2012 at 07:12 PM. |
#337 | |
The plenum does not increase efficiency like a large horn would, but does subjectively increase "punch" and "tightness", and allows for a smaller frontal area than if the speakers were front loaded, and is easier to build than a stepped baffle for push pull as is used with speakers requiring a higher crossover point. |
#338 | |
The plenum is indeed as small as physically possible. The magnet actually sits slightly inside the cone of the adjacent woofer. The taper goes from front to back, not side to side. It was also built to mimic the beginning of a horn throat. The horns I built for these were prototypes, too small, and not a sturdy enough construction, which is why I removed them. The sono-tubes are sealed, and of differing volumes to compensate for the fact one woofer is inverted. An interesting observation I discovered along the way is, while a single drivers' Fs is 46, when they are loaded in the slot, the fs dropped to 40 Hz. One can throw Thiel/Small calcs out the window in this type of build: the system Fc lies at 57 and the apparent low frequency limit is 36 Hz. Just imagine what a ppsl sub-woofer application can do ! |
#339 | |
I try to find soms documantation on google. Thanks for sharing with me. kees |
#340 | |
By the way, little offtopic but do someone now what tweeter this is? it sounds better then the magnat metal domes. thanks Last edited by kees52; 5th October 2012 at 02:41 PM. |
| PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread. | Spasticteapot | Multi-Way | 3 | 8th January 2007 05:35 AM |
| Might be interested in this distortion thread | mashaffer | Tubes / Valves | 9 | 14th July 2004 01:08 PM |
| Interested ??? | P901 | Multi-Way | 1 | 3rd December 2003 03:37 AM |
