A Thread for those interested in PPSL enclosures - Page 18 - diyAudio
Old 15th September 2011, 10:19 PM   #171
mondogenerator's Avatar
I love these less conventional ideas!
I have 4 10" ally bass guitar speakers from an old Hartke bass cab that im at a loss to know what to do with. Maybe this would be an interesting way of loading them?
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 15th September 2011, 11:22 PM   #172
Hi -
I'm thinking of doing a quarter wave transmission line loaded PPSL. Is there any reason the transmission line should not exit next to the drivers in the plenum? (it would be split to give one exit for each driver). This would strictly be for HT SW use below 60 hz, and am thinking of using 20hz or so tuning for the transmission line.
TIA for any feedback.
Old 15th September 2011, 11:38 PM   #173
Originally Posted by thoriated View Post
Hi -
I'm thinking of doing a quarter wave transmission line loaded PPSL. Is there any reason the transmission line should not exit next to the drivers in the plenum?...TIA for any feedback.
Hi there: TH's have one side of the driver(s) exiting into the horn mouth, so there seems to be no reason for not locating a TL port into the PPsl, althouigh others on this forum have expressed reservations, without backup data. ...regards, Michael
Old 16th September 2011, 01:50 AM   #174
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by j.michael droke View Post
Hi there: ... so there seems to be no reason for not locating a TL port into the PPsl, althouigh others on this forum have expressed reservations, without backup data. ...regards, Michael
Hi michael,
Agree.Maybe time to test for the crackpot index of whats been argued to be exceptional compared to other good sub implementations.
Crackpot index
As soon as you confine an TL terminus close to a driver front or rear side diaphragm: It turns into a T-TQWT lookalike setup (BP-like) as for the T-QPPSL:
...where I stated to use a lower input power than was simulated.
At a third of the presented input power maximum pressure at the rear side of the drivers would be no more than 165 Pascals/=~123 dB-SPL/at ~26Hz. Nothing to worry about if using quality drivers,IMO..
b
Old 16th September 2011, 01:58 AM   #175
djk is online now djk
djk's Avatar
I took a bad fall any have been out-of-touch for about three days now.
I will be back when I get better.
Candidates for the Darwin Award should not read this author.
Old 16th September 2011, 03:15 AM   #176
djk.....hope you get better soon.
Old 16th September 2011, 03:49 AM   #177
Hi, DJK -
Hope you come back 100%+. Your input is always valued.
I am considering the quarter wavelength TL because my previous experience was that it seemed generally more neutral sounding than BR with still useful bass augmentation & not as rapid a rolloff below. but eventually, for hi quality audio, the delayed backwave started to bother me with music - I think this would be much less of a factor for HT use. If tuned for a quarter wave of 15-25 hz, could still have useful output down to as low as 8hz (with eq) where the K2 amp I plan to use with it cuts off.
Old 16th September 2011, 04:38 AM   #178
Originally Posted by norman bates View Post
perhaps here is some inspiration.
Yes, those are 18's with a 12" diameter port.
It is worth it.
Norman
Do you have any more pics of this build or atleast the bigger pictures showing the whole cabinet?
Old 16th September 2011, 12:40 PM   #179
norman bates's Avatar
I'm not sure what else you want to see............
I have no pics of the build (like 6 years ago), but I could get more pics (they are next door to me). If I remember, they were 48" wide x 36" deep x 22" tall. Again if I remember, it was either 16 or 18ft3 tuned to 27hz. The drivers were not in seperate enclosures, they shared the giant box.
Actually, in the pic, I can see the mdf splitting... oh well...........
Scott, I had some cheapie eminence gamma 15's. Sealed box f3 around 80hz, like no xmax. Djk will fill you in on why yours didn't work well. Don't put too much faith in simulations. Don't give up on ppsl, but you may have to give up on that box going up to 400hz nicely. The design is a bit trickier than I thought.
Norman
Old 16th September 2011, 01:40 PM   #180
WOW thats HUGE Norman.
I just wondered what it looked like in its location and all. Have been trying to see if anyone has done a more narrow PPSL cabinet design yet was all. I know yours isn't.
PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread. Spasticteapot Multi-Way 3 8th January 2007 05:35 AM
Might be interested in this distortion thread mashaffer Tubes / Valves 9 14th July 2004 01:08 PM
Interested ??? P901 Multi-Way 1 3rd December 2003 03:37 AM
Copyright 1999-2017 diyAudio
