Old 27th May 2011, 09:21 AM   #91
hawkson is offline hawkson  United States
edit, save for later
Old 27th May 2011, 10:40 PM   #92
revboden's Avatar
Originally Posted by tb46 View Post
Hi revboden,
Sorry I didn't make myself clearer, maybe this will help:
Yes, that helps. I must build two of these and test to see if the back reflections /top-to-bottom, are positive or negative in-room. I suspect all energy being reflected out is better but you never know with physics...
rev.
Old 28th May 2011, 02:17 AM   #93
Is the PPSL design feasible with 2 LMS Ultra 5400 or is 'too much'
Old 28th May 2011, 02:36 AM   #94
revboden's Avatar
unless your room is the size of a medium sized theater... too much? yes.
Old 28th May 2011, 02:47 AM   #95
huh, approximately how big would a ppsl be with 2 LMS Ultra 5400s?
Old 28th May 2011, 03:18 AM   #96
Huh,
Well, I have 2 5400 Ultra LMS and I don't know what I should do with em. Should I only make a 1 sealed?
Old 28th May 2011, 12:49 PM   #97
tb46 is offline tb46  United States
Hi hawkson,
Just a quick simulation:
Oliver
Old 28th May 2011, 01:47 PM   #98
GM is offline GM  United States
GM's Avatar
'Too much' is an individual's choice. If I had a house capable of handling such output without having it collapse around/on me, a pair of DTS 'wannabes' and a few kW would be just about right for the dynamic headroom/low distortion/BW I'd want for some movies, games: AVS Forum - View Single Post - Top 5Hz-15Hz BluRey movies
GM
File Type: gif TC Sounds LMS 5400 DTS wannabe - dual - 4 kW each.gif (17.4 KB, 668 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 28th May 2011, 03:47 PM   #99
Thanks TB46. The graph you posted seems underwhelming. I am not sure I am reading it right, but LMS ultra 5400 achieving only 90 dbs at 20hz, is that right? BTW< I have Lab Gruppen 14000 powering these.
GM, thats the LMS Ultra 5400 series 2? I believe I have an older version of the lms 5400...
Old 28th May 2011, 04:06 PM   #100
GM's Avatar
Dunno, it's whatever someone posted awhile back: ~19 Hz Fs, 0.31 Qts, 235.5 L Vas
GM
edit: hmm, they are somewhat different than Ricci's, but don't know which specs are earlier or if his are measured........
PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread. Spasticteapot Multi-Way 3 8th January 2007 05:35 AM
Might be interested in this distortion thread mashaffer Tubes / Valves 9 14th July 2004 01:08 PM
Interested ??? P901 Multi-Way 1 3rd December 2003 03:37 AM
Copyright ©1999-2013 diyAudio
