A Thread for those interested in PPSL enclosures
Old 26th May 2011, 06:10 PM   #81
LarryMcConville is offline LarryMcConville
Hi revboden,
I'm looking at this exact shape to experiment with as a manifold design for a PPSL-IB build. Would contain one pair of 21SW152-4 drivers.
Larry
Originally Posted by revboden View Post
djk, ever tried a slot shaped like this
(one side cutout to show detail)
Old 26th May 2011, 11:25 PM   #82
revboden is offline revboden  United States
revboden's Avatar
Originally Posted by LarryMcConville View Post
Hi revboden,
Larry
(retrieves jaw from floor)
That should be something...
It's hard to see but the design I posted utilizes a semi Parabolic trough.
Old 27th May 2011, 12:27 AM   #83
revboden's Avatar
larry,
I just finished the math.. keep the driver as close to the "back wall / reflector" as possible.
Old 27th May 2011, 01:37 AM   #84
revboden's Avatar
larry, you inspired me to do some more maths.
Old 27th May 2011, 02:26 AM   #85
tb46 is offline tb46  United States
You can also trade of width v. height in the opening:
Oliver
Old 27th May 2011, 02:34 AM   #86
revboden's Avatar
er? trade of width
Old 27th May 2011, 02:55 AM   #87
djk is offline djk
djk's Avatar
Tricks to reduce the rear corner volume of the plenum are to extend the midrange response, are you planning on running a pair of 21SW152-4 up into the midrange?
Candidates for the Darwin Award should not read this author.
Old 27th May 2011, 03:30 AM   #88
Brian Steele is offline Brian Steele  Grenada
I wonder if it's possible to treat the cavity resonance by another means? For example, extend the cavity a bit, then fill it with just enough damping material to tame the resonance? Or is that too much bother for what can be dealt with via active filtering?
Old 27th May 2011, 04:37 AM   #89
djk,
Was this inquiry for me? If so, no sir; purely aesthetic in nature. If not wise to pursue, I certainly will not do so.
I have no plans to run the IB > ~100Hz; ultimately, I'll utilize quad 21SW152-4 experimenting with LPF to best compliment my mains (Danley SH50/SH69/SH50).
I have no experience with an IB install; I plan to run one pair in IB, and a second pair in 12 cubes sealed. I'll measure and listen for which alignment I prefer. Regardless of install, the drivers shall enjoy a PPSL orientation...
Old 27th May 2011, 04:49 AM   #90
Default Post #86
Hi revboden,
Sorry I didn't make myself clearer, maybe this will help:
Oliver
A Thread for those interested in PPSL enclosuresHide this!Advertise here!
PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread. Spasticteapot Multi-Way 3 8th January 2007 06:35 AM
Might be interested in this distortion thread mashaffer Tubes / Valves 9 14th July 2004 02:08 PM
Interested ??? P901 Multi-Way 1 3rd December 2003 04:37 AM
