A Thread for those interested in PPSL enclosures
Old 28th July 2013, 02:28 AM   #501
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by tb46 View Post
Hi GM,
I think DrDyna is talking about something like this (plus the Heil radiator on top):
Yep, that's it, but in my head it was the lower two sections with the Heil up top.
Edit: or 3 sections...I don't know, I haven't done quite as much research on these as I probably should have, so I haven't checked things like..."how big the slot needs to be to be usable up to xxxxx cycles".
Old 28th July 2013, 02:36 AM   #502
tb46 is offline tb46  United States
Hi DrDyna,
: "...in my head it was the lower two sections with the Heil..."
Well, while you're at it, why stop there? :-) As to the slot size: AkAbak.
Oliver
Old 28th July 2013, 02:40 AM   #503
DrDyna's Avatar
Hi DrDyna,
I know right, I have an overactive imagination when it comes to new and interesting speaker designs, by basement is littered with random trial and error remains...
Akabak scares me a little. I suppose one day I'll have to sit down and try to learn how to use it.
Old 28th July 2013, 03:28 AM   #504
Hi DrDyna,
Start with a well known model in Hornresp (AkAbak doesn't like Par for the flare rate), then use David's Export AkAbak Script, and you're of to the races.
Oliver
Old 28th July 2013, 04:35 AM   #505
GM is offline GM  United States
GM's Avatar
Ah! Not too sure I'd want the mid-tweeter doubled up unless the rear driver's HF is rolled off, but otherwise I can't think of a good reason not to try it if you have the drivers. BTW, there is [was?] a company making a high end variant of this a decade or so ago, but don't recall the name now.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th October 2013, 03:28 PM   #506
chris661 is offline chris661  United Kingdom
chris661's Avatar
Hi guys,
I thought about starting my own thread, but figured I may as well post something here first.
I'm thinking of making a PPSL enclosure with a pair of JBL GTO1214s, for PA use. Enclosure volume ~90-100L, port tuning around 30-35Hz. I've seen a standard ported design for Eminence Lab12s that follows similar specification, so I figure I'm not totally off the mark here.
I'm thinking of running the JBLs in parallel off a single channel off a Behringer EP1500, as I've found a good deal on one that has one channel blown.
I like the looks of the dual-15" sub at the start of the thread, and hope to do something similar.
Input would be appreciated
Chris
Old 15th October 2013, 04:33 PM   #507
weltersys is offline weltersys  United States
weltersys's Avatar
After 506 posts, what type of input are you looking for?
Old 15th October 2013, 11:28 PM   #508
chris661's Avatar
Hi Art,
I was hoping to find out if the general idea* of using car subs in a PA/party system was reasonable: I'm aware that these are rather heavy cones, but at the same time I suspect that I could get quite a lot of output for not-much money (I already have the drivers). The cone area of a pair of these drivers is roughly that of an 18"er, and these'll do about 1/2" of one-way excursion cleanly.
*it is just musing at this point: I could sell the drivers on and put the money toward a PA driver. I think I'd struggle to get similar frequency response in a relatively small cabinet, though.
Perhaps I should start my own thread on this?
Chris
Old 16th October 2013, 12:02 AM   #509
djk is offline djk
djk's Avatar
"Perhaps I should start my own thread on this?"
Might be a good idea, this one is rather long.
Candidates for the Darwin Award should not read this author.
Old 16th October 2013, 08:34 PM   #510
Scott L is offline Scott L  United States
Default create saw dust !
It would be nice to see someone else (besides the regulars) actually build one and share the results.
I just built a pair based on my own "inside-out" theory. To be tested over the next few days.
As reccomended, I'll also start a new thread, because they aren't exactly ppsl.
A Thread for those interested in PPSL enclosuresHide this!Advertise here!
PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread. Spasticteapot Multi-Way 3 8th January 2007 06:35 AM
Might be interested in this distortion thread mashaffer Tubes / Valves 9 14th July 2004 02:08 PM
Interested ??? P901 Multi-Way 1 3rd December 2003 04:37 AM
Copyright ©1999-2017 diyAudio
