A Thread for those interested in PPSL enclosures
Old 24th November 2012, 11:04 AM   #391
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Than you very much for your help, guys!
Here are a better sketches of the sub and my home theater room with a 100" screen in precise proportions. I just ordred the boards, but I'll get the drivers and amp only after Christmas. Photos will come later on and I can do nearfield and room measurements too.
Juha
AINOgradient speaker project
Old 4th December 2012, 03:51 AM   #392
OscarS is offline OscarS  United States
Originally Posted by weltersys View Post
A plenum, or slot, is the space between the two speakers.
The plenum does not increase efficiency like a large horn would, but does subjectively increase "punch" and "tightness", and allows for a smaller frontal area than if the speakers were front loaded, and is easier to build than a stepped baffle for push pull as is used with speakers requiring a higher crossover point.
Hmm. how about configuring a PPSL type of setup within a tapped horn? One side (the plenum side) could fire into S2, and the opposite side could be channeled into S3 (or any other S in a multi-segment TH) perhaps?
Old 4th December 2012, 06:44 AM   #393
djk is offline djk
djk's Avatar
Danley has several that meet the PP criteria, minus the slot.
It would be pretty straightforward to do a quad 12 PPSL with the plenum driving a central path bifurcating and coming back down both sides.
Candidates for the Darwin Award should not read this author.
Old 4th December 2012, 01:38 PM   #394
epa is offline epa  Netherlands
the only "problem" with that, is the difference in s4.
soon whe are going to bild a double 15 sub ,then whe try it out.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 4th December 2012, 02:14 PM   #395
tb46 is offline tb46  United States
Hi epa,
When you turn one of the drivers around you get an automatic S2 correction, but now you have to play with the other side of that driver, as you say there will be a difference in S4s (it might not be a problem).
Oliver
Old 4th December 2012, 02:33 PM   #396
Default PPSL T-TQWT
Hi Y'all,
I once drew this one up for ODougbo, it's a bjorno T-TQWT that evolved from a NEO Dan single driver design. The driver was a PE 299-114 6-1/2" factory buyout.
File Type: pdf NEO Dan_ODougbo_T-TQWT_double_notes_2.pdf (30.5 KB, 138 views)
Oliver
Old 7th December 2012, 01:11 PM   #397
hi oliver
i simed both with normal and reversed driver .
that is for s2.
i left s4 the same.
well see how it go's.
. hr driver db
Old 7th December 2012, 01:15 PM   #398
Hi epa,
It'll be interesting to see how it measures.
Oliver
Old 7th December 2012, 08:29 PM   #399
Djim is offline Djim  Netherlands
No need to worry Erik, you'll get there . Just keep an eye on differences in movement between the drivers around 120Hz at high levels.
Old 8th December 2012, 06:14 AM   #400
hi jim
it wil be crossed at 80~100hz steep.
i wil put some sort of stub in the s4 area,for the test.
. hr driver db
A Thread for those interested in PPSL enclosuresHide this!Advertise here!
PVC pipe enclosures with flat wood baffles - yet another dumb Spasticteapot thread. Spasticteapot Multi-Way 3 8th January 2007 05:35 AM
Might be interested in this distortion thread mashaffer Tubes / Valves 9 14th July 2004 01:08 PM
Interested ??? P901 Multi-Way 1 3rd December 2003 03:37 AM
Copyright ©1999-2017 diyAudio
