Hi all
I have just taken apart the sub cabinet of my Logitech Z-2300 and I want to build it into my furniture to have the ugly box out of sight. Having it taken apart, I wonder if there is room for improvement. 1. could I replace the driver (it turns out it is a Tang Band W8-670Q). specs (wich mean absolutely nothing to me): Fs = 42.95 HzRe = 7.80 ohms Le = 7328.42 uH L2 = 3120.63 uH R2 = 52.25 ohms Qt = 0.52 Qt Qes = 0.57 Qes Qms = 6.49 Qms Mms = 50.81 grams Rms = 2.112233 kg/s Cms = 0.000270 m/N Vas = 10.35 liters Sd= 165.13 cm^2 Bl = 13.755757 Tm ETA = 0.14 % Lp(2.83V/1m) = 83.66 dB Or could I imrove the size of the cabinet: The original enclsure is 30,5 cm x 25cm x 25 cm (inside) = 12" x 10" x 10". Maximum inside size of the new enclosure is 23cm x 41cm x 38cm (= 9.1" x 16,1" x 15") The original is ported with some weird U-shaped plastic tube, diameter of the outside hole 5,3", the diameter of the tube itself is 3", the length of the tube about 22". I hope the specialists here have some interesting things to say! Thanks in advance! Erik Blokpoel |
#2 |
Greets!
First things first, these specs are somewhat different than what is published, so are yours measured or........? GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 | |
#4 |
Hi erikb1971,
Are the specs measured? In any case they are not the specs of a Tang Band W8-670Q. Please, see TB's website. Regards,
Oliver |
#5 |
The specs seem to be measured from the original speaker: logitech w200of120-02f. I found on th einternet it was a tangband driver, but that does not seem to be the case. Again sorry for the confusion!
#6 |
Hi GM,
One phone call, and you beat me to it. :-) Regards,
Oliver |
#7 |
Hi erik1971,
Here is the Boxplot output for your speaker in a box with your dimensions, vented w/ 3"Dia. Port. Regards,
Oliver |
#8 |
wow... that looks pretty impressive... but I have no clue what that means. It is bedtime in Europe, so Iam gonna take a good night sleep and study it in the morning. If Iam not able to figure out what it means I will get back :-) Thanks a lot for the effort!
Erik |
#9 | |
Why not build a multi-folded TH using 0.5" Ply (using the driver specs here-above): b |
#10 |
The simplest way of doing it is using an internal volume about 20% to 30% larger with the original vent, anything more radical may not suit any amplifier EQ. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| Help! Logitech z-2300 | ckim8 | Multi-Way | 0 | 27th December 2008 09:20 PM |
| Room for improvement | shatt3r | Car Audio | 0 | 17th November 2005 06:26 AM |
| Problems with P3A after refitting | Cradle22 | Solid State | 8 | 1st July 2003 10:28 PM |
| Page generated in 0.10667 seconds (84.83% PHP - 15.17% MySQL) with 11 queries |
