best encl. volume for Eminence Lab 12 in a sealed sub?
Old 15th November 2010, 12:10 AM   #1
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
Default best encl. volume for Eminence Lab 12 in a sealed sub?
Researching a 12" unit for a small sealed sub and this driver seems to get the best reviews and goes low and loud
Eminence :: Eminence LAB-12 ONLY 129.99
I copied this from another forum (what is B2?) ; am I right in thinking that I should keep the box volume small for a low F3?
"The LAB12 requires 2.85 to 3.6 cubic feet for vented alignments. Sealed alignments are 1.8 to 3.4 cubic feet (B2 and D2 respectively). The sealed box is very forgiving for size changes. As the box size increases beyond the B2 size, the group delay improves, F3 moves higher, and power handling ability gets worse.
The LAB12 has an efficiency bandwidth product of 56, making it ideal for use in a sealed box."
Old 15th November 2010, 03:16 AM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Bill poster View Post
..The LAB12 has an efficiency bandwidth product of 56, making it ideal for use in a sealed box..
Agree, but would also work well in a large ported box too.
b
Time to get some
Old 15th November 2010, 12:29 PM   #3
need to keep the enclosure as small as i can, around 25 litres, a 12" unit is my optimum size. I was going to go for a mivoc but this Eminence works v well in a sealed and the new tangband 12" looks even better on the graph tho much more expensive..
Old 15th November 2010, 06:58 PM   #4
hellonwheels is offline hellonwheels
gti1214d is cheap in the US... $83.
Old 17th November 2010, 10:29 PM   #5
azimut is offline azimut  Italy
There is well documented project (only in Italian)
38,73 liters
AudioFanaticProgetti-Il_Bimbo.html
Old 18th November 2010, 12:40 PM   #6
The Eminence lab 12 does 38hz f5 in a 25 litre sealed but is perhaps more suited to large enclosures so thinking 10" is the way forward. The 10" dayton Titanic and TC epic 10' look good as a BR or sealed.. and they are for more suited to a smaller enclosure. The Dayton is especially good, I modelled it down to an F3 of 28hz in a 20 litre BR
Old 18th November 2010, 03:19 PM   #7
..The 10" dayton Titanic.... look good as a BR or sealed.. and they are for more suited to a smaller enclosure. The Dayton is especially good, I modelled it down to an F3 of 28hz in a 20 litre BR
Are you sure?:
b
File Type: jpg DaytonTIT280C-4_20Lported vers._48L-T-TQWT.JPG (513.8 KB, 1145 views)
Old 18th November 2010, 05:26 PM   #8
hmm.. tried modelling it again and its 32hz (fb 29) not 28 hz; you are right.. what did I read wrong?
btw I'm using the dumax readings in linear team.
Still good tho!
Old 20th November 2010, 12:31 PM   #9
..btw I'm using the dumax readings...
So did I, see the picture,the unique Dumax report doesn't improve f-3dB..
OTOH, I would prefer a sloping FR over a flat if a ported box: only if the port length would be different, i.e. much smaller, but not if I had the opportunity to choose the more powerful T-TQWT.
b
File Type: jpg DaytonTIT280C-4-nominal-TS-vers-Dumax-TS.JPG (471.3 KB, 1076 views)
Old 22nd November 2010, 11:10 PM   #10
bloozestringer is offline bloozestringer  United States
bloozestringer's Avatar
Wayne over at Pi speakers (Audioroundtable.com) has a design that utilizes the Lab12 (3Pi sub). I have heard it and it works well. Ask him for the design and he'll email it to you. I'm sure he has all the measurements he did as well.
best encl. volume for Eminence Lab 12 in a sealed sub?Hide this!Advertise here!
Eminence lab 12 and dayton audio hpsa500 for sale nate1r Swap Meet 1 15th November 2010 01:43 PM
Eminence or P.Audio ? Open Baffle or Sealed Predator864 Multi-Way 0 23rd January 2009 12:51 PM
Eminence Lab 12 + Amp + Box combo metaverse Car Audio 57 8th January 2009 12:42 AM
amts and lab 12 motu Multi-Way 3 27th March 2005 09:29 AM
Move Over LAB 12, Here Comes Its Little Brother........ OMNIFEX Multi-Way 16 13th January 2004 01:21 AM
Copyright ©1999-2017 diyAudio
