Old 6th November 2010, 06:11 PM   #1
ahl395 is offline ahl395  United States
ahl395's Avatar
Default A few Subwoofer questions.
Hi everyone.
Im a bit of a noob/beginner and this is my first speaker building, so i need some advice.
I have a few questions with subwoofers.
First Question...
Would it be okay to have a Subwoofer and a Full/Extended Range speaker in the same enclosure? Or should they be seperate?
Second Question...
How does this subwoofer look? I know reviews are good but looking for another opinion.
Dayton SD315-88 12" Shielded DVC Subwoofer | Parts-Express.com
Third Question...
Looking at the hookups for this sub, HERE... it shows double the hookups of a regular speaker... how exactly do i hook that up and where do i plug all of those into?
Fourth Question...
Im planning on buying two of the subwoofers above, how does that compare for bass output to ONE of these...?
AudioSource PSW112 12" 175 Watt Front Firing Subwoofer | Parts-Express.com
Fifth Question...
How does the subwoofer above work exactly? it has its own amp in it? so then it doesnt need power from the receiver? how do i hook it up to the receiver, just regular speaker wire?
Last question...
Is pine wood ok to make a subwoofer enclosure out of?
Old 6th November 2010, 06:57 PM   #2
Originally Posted by ahl395 View Post
First Question...
Generally not a good idea to put a FR driver in the same enclosure as a sub unless you made a separate internal box for the FR - besides you will most likely want the sub and the FR located and oriented in different parts of your room.
Second Question...
Its a decent candidate, not a huge amount of xmax(cone excursion) bit workable. What are your design targets, how are you going to use this sub, and also how are you going to drive it - with a plate amp you build into the enclosure or with a separate amp ?
Third Question...
Each coil of that driver is 8 ohms - if you connect them in parallel ( plus to Plus and negative to negative ) then take the plus(s) and Negative(s) to the amp you will have an impedance of 4 ohms. Make sure any amp you choose for this sub can handle a 4 ohm load.
Fourth Question... Im planning on buying two of the subwoofers above, how does that compare for bass output to ONE of these...?
Difficult question to answer with out knowing what amp you are going to use and what enclosure design you will choose.
Fifth Question...
The AudioSource has a built in plate amp so you can just take the sub(LFE) line level output from your main amp (if it has it) and send that to the AudioSource line level sub input. Otherwise you can (using speaker wire) take the left and right speaker outputs from your main amp and put them into the the high level inputs of the AudioSource sub amp.
Last question...
Pine is a very poor choice for a sub enclosure, 3/4 inch MDF or baltic birch plywood both with internal bracing are recommended
Old 6th November 2010, 07:46 PM   #3
ahl395's Avatar
Ah okay, so if i put them in seperate enclosures do i need a crossover at all?
Oh okay, do you have any other suggestions? that are around the same price?
I guess my design target would be to get the best bass output?
Im not sure how im driving it yet... ive been referred to plate amps, but i also have a 200W Receiver/Amp I can hook them up to. It would make it cheaper to go that route (ill explain my budget later). Although it is 2 Channel so im not sure if/how i could hook up the subs being that they have two hookups each. (im planning on buying two of these subs). Although i guess splicing would be the answer, im doing it now and have before without problems, even though i know its not "good"
Hmm... a little confused
My amp cant do 4Ohms, id rather hook it up at 8... so could i just hook up one of those sides? but if it has two voice coils wouldnt i only be using one that way?
I ran WinISD to find an enclosure, this is what it gave me...
W: 18 in
H: 28 in
D: 12 in
Vent: 4" hole
Ah okay... yeah i would have to use the speaker wire method.
It might be best for me because then ill still have the 200W from my amp to use elsewhere than the sub. Although this way i only get one sub, even though its more powerful than the other two alone, is it better? myself would tell me the two, lower (but higher combined) powered ones would be better.
[/QUOTE]
Ack, okay. thanks.
Otherwise... if you can help me change all of what im looking at, my overall budget is from $100-$150 for everything. My main concern is to have bass, so im looking at getting two subwoofers, as well as an Extended Range speaker. Those plus any plate amps or crossovers i need... not sure how much that will all be but im hoping under $150. the enclosures im building myself so they shouldnt be too much of a concern and should be cheap.
Old 6th November 2010, 08:32 PM   #4
godfrey is offline godfrey  South Africa
The Audiosource powered sub is the cheap and easy option. Don't know how good it is, but it's everything you need in one box, ready to go.
btw, Here's more info on it: AudioSource :: Products :: Speakers
You could probably get better results with the Dayton drivers but then you'll need the drivers and an amp and a crossover and a box, plus lots of head-scratching about the design etc.
... my overall budget is from $100-$150 for everything...
Yikes! The powered sub is $200 on it's own...
Sounds like you already have a receiver you can use to power the main speakers? So your budget just has to cover the main wide-range speakers plus either a powered sub or passive subs and an amp for them?
Old 6th November 2010, 08:46 PM   #5
Just saw your second post now.
Here's an idea: If you connect the two voice coils of the Dayton in series instead of in parallel, you end up with 16 ohms instead of 4 ohms. That will be easy for your amp to drive. Also, if they're hooked up like that, they'll be able to take the full output from your 200W/8ohm amp without frying.
Maybe then you can use the 200W amp to power the full-rangers and the subs.
Old 6th November 2010, 08:51 PM   #6
ahl395's Avatar
Hmm... well usually cheap easy and ready to go solutions arent the best
thanks for the link though, still lacking alot of specs that are listed on the other sub im looking at, so not much to compare by... so not sure i want to buy that.
Hmm okay, thats what i thought too. but if i use the amp i have it would cut down the price... and can you put me in the right direction with the crossovers, i really dont know much about them, what kind i need, or even if i DO need one. so can you help me with that? much appreciated
well the Audiosource sub is on sale for only $100 here...
[/QUOTE]
well the amp i have for this is 200W, just for the two subwoofers and Extended Ranges. I know that in the end they'll be a little underpowered... but my only other option is to get seperate plate amps for the subwoofers (or at least one of them), if its in budget that is... not sure what plate amp i should get though.
Thanks for your reply!
Old 6th November 2010, 08:54 PM   #7
ahl395's Avatar
okay... sorry for being a beginner here but i dont understand what "in series" and "in parrallel" mean could you explain?
But yeah, 16 ohms would definetly be better if i could hook it up that way.
could you just explain how i would hook it up this way? greatly appreciated
Old 6th November 2010, 09:27 PM   #8
Like so:
If each coil is 8 ohms then series connection gives 16 ohms total and parallel connection gives 4 ohms total.
Old 6th November 2010, 10:13 PM   #9
Honestly, from a price point if view, I think that you should just go with the AudioSource PSW112 12" Subwoofer it's on sale for $99 from now until the end of the year. It is a complete solution that you really could not build for less $$
You can't use your existing amp to drive the sub you where thinking of building directly - you would need either a sub crossover network that combines the L+R channels of your current amp and then also filters out all the frequencies above about 80Hz and then passes this signal onto the sub driver - or - buy a plate amp similar to what is in the AudioSource to perform this function, best value/price right now is this Dayton one which is on sale for $99.
Bottom line is that if you want to build a complete sub that works, it is going to cost you (in any event) more than $99 for the Audiosource - if you want to build something better than the Audiosource then you should budget in the $200 > $300 range
Just remember that for less than $200 you would get 2X complete Audiosource subs that are a simple plug in to what you already have - hard to beat from a DYI point of view - lol
Old 7th November 2010, 12:44 AM   #10
ahl395's Avatar
Well i would like to try and avoid buying the AudioSource subwoofer... because i think two of the Dayton sub's would be better than one of those, right? (i cant buy two of the AudioSources)
I looked at some Sub Crossover networks... didnt know i need that But its alot cheaper than buying plate amplifiers...
How are these two?
http://www.amazon.com/PLXR2-Electron.../dp/B0002BEWYM
Amazon.com: Legacy LXR1 Electronic Subwoofer Crossover Network: Electronics: Reviews, Prices & more
And with these, the amp i have now will power the subwoofers right? this will just filter out high frequencies?
buying those i could easily set up what i want for in my budget i think
Various Subwoofer Questions - Thanks topher_m Subwoofers 1 1st March 2008 04:44 PM
AR9 Subwoofer Questions dc270 Subwoofers 0 7th May 2006 12:17 AM
subwoofer questions Jacobus Subwoofers 9 15th December 2005 12:05 PM
Small subwoofer questions bigparsnip Subwoofers 39 28th April 2004 07:25 AM
Subwoofer design questions Theli Subwoofers 18 15th January 2004 04:38 AM
Page generated in 0.17010 seconds (86.29% PHP - 13.71% MySQL) with 11 queries
