Old 6th November 2010, 02:23 PM   #1
dannyjmf's Avatar
Default Recommend a 8" Subwoofer driver
I am planning to build a subwoofer system with a vented box of 38L and 2.5in vent 12in long tuned to about 29 Hz ... Any driver to recommend for this box specification? Thanks
Old 6th November 2010, 03:21 PM   #2
no gas is offline no gas  United States
Why would you tune a box before you know what woofer you are using? If you are stuck with a certain size box first find a woofer that will work in that volume THEN tune the port. What you are doing now is like buying a tire first then asking what kind of car you should put it on!
Old 6th November 2010, 03:40 PM   #3
WinISD. Go forth and google.
http://blog.liammartin.com
Old 7th November 2010, 01:10 AM   #4
dannyjmf's Avatar
The reason i selected this volume size and tuning Frequency is due to this is my desired target design. I don't have much space in my bedroom. Dimension of the box i will settle on is W=10in, H=20in, D=16in.
Actually i do have a box with the same volume and tuning frequency with an unknown brand woofer. It sounded quite ok (extended to about 34Hz) but tend to bottom up when driven hard. I am planning to rebuild a box with a same internal volume but with different dimension but to try out different brand woofers. The vent length is not critical as i can shorten or make it longer. I would like to target 38L as my maximum internal volume to keep my project cost low down and also to save space
So if i want to get away with a small box such as this size(besides recommend woofers), what alternative can you guy recommend? Thanks alot...
Old 7th November 2010, 01:16 AM   #5
Maybe better off building a transmission line for bass extension
Old 7th November 2010, 01:25 AM   #6
dannyjmf's Avatar
i heard that to build a transmission line system most often will end up in a big box(not sure or not).... how about isobaric system? i do not want another driver to stick out in front of my box!
If possible can have a medium size box to deliver massive amount of bass ... Thanks...
Old 7th November 2010, 01:28 AM   #7
depends how you fold it and what multiple/divisible of a wavelength you use!
Old 7th November 2010, 01:31 AM   #8
dannyjmf's Avatar
if say for example i am going for isobaric system, how am i going to hide the second driver from view.... i heard it is possible to do so .... ?
Old 7th November 2010, 03:48 AM   #9
GM is offline GM  United States
GM's Avatar
JL Audio - Car Audio Systems
As you can see, it eats up a lot of space, making a small cab not so small.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th November 2010, 04:41 AM   #10
tinitus is offline tinitus  Europe
despite its car subs, some of the cheaper RE Audio might interesting
Please recommend a 10" subwoofer okmat Subwoofers 18 7th May 2010 10:18 PM
JVC 8" Subwoofer Driver form109 Subwoofers 0 19th December 2009 04:43 AM
Please recommend Subwoofer Driver mart34 Subwoofers 5 25th September 2008 11:07 PM
Recommend 8" Driver for Aperiodic Cabinet konut Subwoofers 4 17th September 2008 11:16 AM
Servo subwoofer using 15" driver kanaddict Subwoofers 2 20th December 2005 10:54 AM
Page generated in 0.10112 seconds (79.04% PHP - 20.96% MySQL) with 11 queries
