Old 31st October 2010, 02:27 PM   #1
Default Dayton DSC205-4
I'm thinking of building stereo subs to compliment a 6-element 3" fullrange line array system I built recently.
I tend to like smaller drivers for subs and 10" is about the largest I would consider.
I designed up a system using two Dayton DSC205-4 8" woofers in series in a 35 liter box tuned to 37 Hz. I will build two of these boxes.
Has anyone tried this driver? Specs look great but they don't tell the whole story. Any input would be appreciated.
Brian
Old 31st October 2010, 04:32 PM   #2
chris661's Avatar
A 35 litre box for a pair of 8" drivers would likely be too small. What do your sims look like?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 31st October 2010, 05:13 PM   #3
Sim attached.
Old 1st November 2010, 08:14 AM   #4
chris661's Avatar
Thanks.
It actually looks like the cabinet is large enough. It does roll off ~40Hz though (smaller box means less extension). Still, I'd expect room gain (especially if put against a wall) to fill things in nicely.
Dayton usually make good stuff. And with nearly 9mm of Xmax, you've got plenty of displacement.
Enjoy!
Old 1st November 2010, 12:58 PM   #5
Thanks Chris661! I appreciate the input.
Old 1st November 2010, 01:24 PM   #6
DJK265 is offline DJK265  United States
Default Why not?
The Dayton 10" Quatro is on sale right now. For a few $$ more they're worth looking at. Dayton QT255-4 10" Quatro Subwoofer 4 Ohm | Parts-Express.com
Old 1st November 2010, 04:13 PM   #7
Thanks for the tip. The 10" looks like a good unit also but I think for my purposes, the 8" will be better. The 10" gives me a few Hz better extension and a power handling (smaller Xmax though) in trade for a box twice the size (for a double-ten).
This 8" looks almost too good to be true. I'm pulling the trigger today.
Dayton DTA-1 amp + Dayton PA130 5" driver Godzilla Full Range 7 5th August 2011 03:48 AM
Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? wigginjs Multi-Way 6 3rd March 2008 08:56 PM
Vifa/Dayton/Dayton... First speaker for me, finally! alexcd Multi-Way 6 29th November 2006 10:54 PM
Dayton DA aluminum cone woofer + Dayton DC28f tweeter springy101 Multi-Way 7 15th March 2006 05:22 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Page generated in 0.08071 seconds (76.72% PHP - 23.28% MySQL) with 11 queries
