Old 31st October 2010, 06:22 AM   #1
form109 is offline form109  United States
Default Tangband 5x7 Woofer?...what sorts of applications is this suitable for?
i've seen that 5x7 Tangband Woofer at Parts-Express for a while now and im wondering what sorts of applications it would be suitable for....obviouslly the 5x7 formats would make these seem fit for Car audio apps (given the oblong shape of the TB oval woofers wont fit stock openings without mods)
the listed FR is 40-500 so it obviouslly can't be used for a Typical 2 Way Design...it seems to be leaning towards bass applications
but with a 3 mm xmax it doesnt seem like a canidate for a subwoofer (unless its for a small room at very moderate volumes)
any thoughts on this one guys?
Old 1st November 2010, 07:50 PM   #2
Hey form109, it would seem that they are intended for low bass support with a wide range driver. This would allow for use of a fairly narrow cabinet. This tends to improve the SAF of a speaker.
Peace,
Dave
Old 1st November 2010, 08:20 PM   #3
chris661's Avatar
Hmmm...
If it overloads gracefully, 3mm Xmax can be reasonable, especially if there's more than one used. I know my subwoofer drivers have 3mm Xmax (they go overload nicely though, 8-10mm p/p before harmonics become apparent), but I'm never left wanting (then again, it's a small room).
As Dave said, having them narrow would help SAF. 2 per side backed with a subwoofer for the really low stuff would probably do quite well.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 1st November 2010, 09:03 PM   #4
picowallspeaker's Avatar
Cone material ,PP or PET Naftalate ,should point it to car environment ---or cat habitat
Old 8th November 2010, 06:04 AM   #5
Checked Tangband's Website.....and apparently It Is a Subwoofer....looks intreasting
Old 8th November 2010, 08:51 PM   #6
chris661's Avatar
It's not a subwoofer. There isn't the surface area there to move sufficient air.
Still, using them for rear speakers in a car may be something they had in mind.
Old 8th November 2010, 08:53 PM   #7
Boscoe is offline Boscoe  United Kingdom
Why are there odd shaped speakers like this in te first place?
Old 10th November 2010, 03:41 AM   #8
Tangband has it Listed as a Subwoofer.........and keep in mind Tangband does make small subwoofers....an example would be their 5" Neodymium subwoofer...which has 3 Times as much X-Max...but you get the point.
if a 5 1/4" Woofer is considered a Subwoofer why shouldn't a 5x7" Woofer be considered a sub.
Old 10th November 2010, 06:17 AM   #9
chris661's Avatar
A 5x7" driver is commonly used in cars. Also, as someone mentioned earlier, a narrower driver gives a narrower baffle, so WAF would be higher.
Old 10th November 2010, 03:38 PM   #10
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
..but with a 3 mm xmax it doesnt seem like a canidate for a subwoofer (unless its for a small room at very moderate volumes)..
I think these drivers are very good for sub intended for music if placed within ~0.7m from a room(< ~50 m^3) corner.
A doable 34.5L= 1.22 cu.ft folding challenge:
b
2 way suitable woofer? asiquis Multi-Way 1 24th July 2010 01:29 PM
suitable woofer for TL CharlieM Planars & Exotics 0 14th March 2008 10:03 PM
Bought a woofer, need help finding suitable enclosure Simpleton Subwoofers 12 11th May 2007 02:42 PM
suitable horndesign for TangBand W8-740 Mayday Subwoofers 10 15th April 2007 03:12 PM
Page generated in 0.09960 seconds (84.07% PHP - 15.93% MySQL) with 11 queries
