Instantly deepen your sub? - Page 2 - diyAudio
Old 2nd November 2010, 08:19 PM   #11
Might be safer in your bloodstream than clogging your lungs and depriving them of air.
No, helium doesn't seem backwards: it seems the "natural way" what you are proposing. But I don't think it is right.
No trouble getting tweeters go supersonic and far, far higher than most ears go.
But getting lower distortion, linearity, and damping from proper impedance match will always be a problem except for gas-speakers. That's my take on the physics.
Of course, I'm the ESL guy who is always ridiculing cone speakers which shake big hunks of heavy cardboard to make sound in thin air.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio
Old 2nd November 2010, 08:20 PM   #12
diyAudio Member RIP
Heavy gas is not what you want inside a subwoofer, the lighter the gas
the better as I recall. I seem to remember some speakers allegedly
loaded with helium filled plastic bags to increase effective box volume.
rgds, sreten.
Old 2nd November 2010, 08:39 PM   #13
onform is offline onform  United Kingdom
onform's Avatar
I wonder what would happen if you placed and sealed a large helium filled balloon over the front of a driver and pointed it upwards? would you get a huge low mass omni directional driver? you could even have a tweeter mounted coaxially inside on a rod pointing forward as presumably higher frequencies would just past straight through? If you filled all but one mounting holes you could use the last and mount a valve in it??
Or am I just bonkers?
Old 3rd November 2010, 11:07 AM   #14
djk is offline djk
djk's Avatar
"the lighter the gas
the better as I recall. "
That's backwards. The gas must be denser than air. The air load presented to a driver is a poor impedance match because the air is so light compared to the speaker cone.
Candidates for the Darwin Award should not read this author.
Old 3rd November 2010, 03:22 PM   #15
diyAudio Member RIP
Nope. It has nothing to do with impedance matching. Lighter than air
gases make the effective box volume appear larger and heavier than
air gases make the effective box volume appear smaller. In the accounts
I've come across only hydrogen or helium is "apparently" suitable. Some
accounts talk about using heavy gas to restrict movement, but that
is pointless, just use a smaller box or restraining volume if needed.
Hydrogen and Helium are the only gases readily available with inversion temperatures at or below the ambient temperature of the human environment.
It will be found that a gas with a negative Joule-Thomson coefficient will have a very high adiabatic compressibility, yet will have a relatively low isothermal compressibility; therefore, at mid to low frequencies the compliance of this gas is very high, but at ultra-low-frequencies in which the compression process is isothermal the compliance is very low and the response of the loudspeaker system is limited at infrasonic frequencies. As will be seen in the preferred embodiment of this invention, this is a very advantageous situation when applied to loudspeaker technology. "
I cannot remember where I read about the helium bags.
rgds, sreten.
Old 3rd November 2010, 04:16 PM   #16
As I poorly understand these things, you are right that the result is like the box is smaller if a heavier-than-air gas is used. But I think that is no different than saying the impedance match is better or that smaller boxes make the interior compression a bigger part of the compliance. I'm not sure if there is a benefit that couldn't be achieved by adjusting box size... dunno.
The real benefit of the heavier gas is at the front side of the cone. If the room were full of SH6, the cones would work better due to better impedance match. But that can't be done unless you wear a SCUBA mask and tank while listening to music.
But if you use the "megaphone" design, you get some of the advantages in proportion.
Old 3rd November 2010, 05:11 PM   #17
Heavier gas, slower speed of sound, longer transit time through box, 'bigger box'. Doesn't that make sense?
Old 3rd November 2010, 05:44 PM   #18
imfree707's Avatar
Send a message via Yahoo to imfree707
Default Lack Of SF6
I don't know about sulfur hex "deepening" the sound of subwoofers, but lack of SF6 made a hell of a noise in this "switch"!
You Tube-500kv Arc
YouTube - A 500KV three-phase switch failing to interrupt a 2,000 Amp arc Boulder City, NV (Lugo)
Impressive-sounding on a good system, especially the echo slap-back when that 50ft tall arc breaks!
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
Old 3rd November 2010, 06:45 PM   #19
Yea, removing the insulator generally has that effect on high voltage equipment. SF6 is a dielectric. Had a similar experience fixing a power outlet that had been improperly wired from 3 circuits. 90% of my screwdriver vaporized. Well, it seemed as scary at the time.
Old 3rd November 2010, 07:18 PM   #20
imfree707's Avatar
Default Agree!
I agree! The linemen saw the 50ft arc from a safe distance. Having a screwdriver explode into vapor while in your hand is actually more dangerous! The linemen weren't endangered by flying bits of molten steel!
Fuse is blowing instantly (SSE) Divad89 Tubelab 14 14th September 2010 03:52 PM
Copyright 1999-2017 diyAudio
