Old 29th October 2010, 02:09 AM   #1
Default Can you model a vented box in HornResp?
I see how to make a 4th order bandpass, is there a way of making a rear vented box?
Old 29th October 2010, 02:47 AM   #2
soho54 is offline soho54  United States
Use Nd, Tools>chamber>Rear Vented, and enter a Vrc, Lrc, Ap, and an Lpt.
Old 29th October 2010, 03:31 AM   #3
tb46 is offline tb46  United States
Hi hellonwheels,
Or you could do it with the Compound Horn model (for your 6th order bandpass).
Oliver
Old 16th November 2010, 05:43 PM   #4
It seems to ignore the rear vent in the spl output... How can I get it to include the rear vent as spl? It does seem strange that it would totally ignore the output from the vent.
Old 16th November 2010, 06:56 PM   #5
You have to look at the Combined SPL graph.
If you open the Wizard up you can flip between the driver, port, and combined outputs pretty easy. Seems like it's called default, 2nd, and combined.
Old 16th November 2010, 09:08 PM   #6
Give this a try, just an example. You can also add Ap1/Lpt:
Oliver
Old 16th November 2010, 09:12 PM   #7
Thank you, that was helpful.
Old 16th November 2010, 11:03 PM   #8
David McBean has given us a wonderful tool in Hornresp. Take a look Help, Page 19 for the compound horn, and you can use the Loudspeaker Wizard (e.g.: Response - Horn S1-S3 - Combined).
Oliver
Old 11th December 2010, 12:31 AM   #9
Bringing this thread back to life
Given I have the following parameters, what do I select to model a 6th order bandpass? (confused between the various suggestions on this thread)
And how do I approach the modelling if I already have a cabinet?
thanks!
Old 11th December 2010, 01:27 PM   #10
MaVo is offline MaVo  Germany
"normal" driver configuration
Vtc + Atc = Front chamber, S1+S2+L12 = Front Port
Vrc + Lrc = Rear Chamber. Ap1+Lpt = Rear Port
in compound horn, you can use S5+S6+L56 as rear Port.
th speaker hornresp model needed... please help justint Subwoofers 7 9th February 2010 06:21 PM
How well does Hornresp model a TQL? Geek Multi-Way 3 21st October 2009 12:17 AM
Trying to model Imperial BLH with Hornresp - Is this right? just a guy Subwoofers 6 28th March 2008 11:50 PM
Can I mod an old labriynth box to be a vented box? MikeHunt79 Subwoofers 7 23rd May 2006 06:44 PM
Closed box sub in vented box ? MadMax Multi-Way 3 17th May 2003 12:24 AM
Page generated in 0.09932 seconds (77.11% PHP - 22.89% MySQL) with 11 queries
