#21 |
jackinnj said:
why not just buy an Aeolian Skinner pipe organ? ---------------------------------------------- As an alternative to your suggestion, my current plan is to build a subwoofer array and then play some of these. World's Largest Organs Does this meet with your approval? James
#22 |
Dave from Planet 10 said, in part:
But if room gain rasies the system Q (in the room) to above 1, that isn't very good. With that many drivers in such a small room they become a VERY significant part of the "box". --------------------------------------------- Wow, this is a really fascinating point. Can you describe some factors in the interaction here? Perhaps you can suggest where I can learn more about room q and how it would apply? Great Stuff! James |
#23 |
And what types of slopes??
the higher the crossover point and the more shallow the slope I would think that the more likely you are to have a problem getting good convergence with them horizontally. It seems that excellent integration with the subs is frequently difficult to achieve. I guess that my problem with the horizontal array is that to me they _seem right_ if they're vertical on the sides. Since we're talking scientifically _big grin_. You've already said you're going to build them so they can go either way, so I guess it doesn't really matter that much. But I _really_ want to know how they work out best. Please send me an e-mail when you're done if I don't seem to be around when you make a final post on it. Boy, threads move down very, very quickly - so quick that if you're gone a short time, they've disappeared. Later Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
#24 | |
#25 | |
I have a recording of the Wanamaker organ made in 2001 with its current organist, Richard Peter Conte. Its an amazing CD. Recorded using fiber optic cable and dozens of microphones around the atrium, this CD reproduces all low frequency sound produced by the Organ, nothing was rolled off!
Selections include Night on the Bare Mountain, and Nimrod from Variations. This recording is the last made and is the most complete sound yet of the organ following the recent restorations. (Several Divisions need to be restored) As a note, the string division alone for this organ is composed of 6992 pipes...And the organ uses over 160hp to power the blowers. Anyway... Buy this CD. entitled Magic - Peter Richard Conte at the Wanamaker Grand Court Organ. This will test any systems low frequency response. Quote:
#26 |
While not quite wall to wall, I am currently doing an installation with 4 12" woofers per channel, all horizontal. The enclosures are actually a stage upon which the mr/hf speakers will sit.
The difference with this installation is that the bottom of the enclosure is actually the floor of the room. The flooring has been removed between the joists so the the rear wave is vented to the crawl space - essentially a real infinite baffle. Fs will be 24Hz and Qts will be .35. It's easy to bring the Q and low frequency response up with a little bass boost but given the room gain this may not be necessary. If this thread is still going, I'll report the auditory results. |
#27 | |
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#28 |
James, IMO your plan is fine. I have always liked multiple drivers to keep distortion very low. You'll wind up with "effortless" bass. I currently am running 2 Tempests and will shortly build my 4 AV-12s into a single box. Sealed is the way to go, too. Should be very musical and should knock you off the couch during movies.
![]() If the room creates enough problems, you can always pick up a BFD to tame the "lumps". ![]() Pete |
#29 | |
#30 |
Ken L said:
But I _really_ want to know how they work out best. Please send me an e-mail when you're done if I don't seem to be around when you make a final post on it. -------------------------------------------- Thanks Ken I will keep you in mind. |
| Designing for on-wall/near-wall speaker placement | morbo | Multi-Way | 4 | 27th November 2010 05:52 PM |
| in-wall/on-wall speaker? (axiom w-22 clone?) | Scott_fx | Multi-Way | 0 | 22nd February 2007 03:08 AM |
| In-wall vs bookshelf spk flush with wall | darascott | Multi-Way | 3 | 1st October 2005 04:16 PM |
| In-wall subwoofer? | DIAR | Subwoofers | 14 | 9th March 2005 06:24 PM |
| In-wall NSB line array! | mazeroth | Multi-Way | 20 | 19th November 2004 05:22 PM |
| Page generated in 0.12492 seconds (82.22% PHP - 17.78% MySQL) with 11 queries |
