#11 | |
#12 | |
Tune by ear, the click test, or flattest impedance curve. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#13 |
Hy,
if you are looking for a more intelligent setup, read some papers: http://www.harman.com/wp/index.jsp?articleId=65 best regards
best regards Kay |
#14 | |
Websters describes "aperiodic" to mean: 1 : of irregular occurrence <aperiodic floods> 2 : not having periodic vibrations : not oscillatory In the last few days I've seen the term used to describe 'Daline' bass loading, egg-shaped enclosure design and restricted ports. As it's such a general term I guess we should be specific about exactly what we mean. |
#15 | ||
I am really surprised that a project of this magnitude did not receive more attention from this board until now.
If he wants to experiment, I was going to suggest he go in the other directiion-port these things for extra "oomph". Use a 4" pipe with a pipe cap on it and make one of the subs a "convertible". See how it sounds. He can always put the "convertible" sub's capped port hole in the back of the enclosure so nobody will see it. Just a suggestion to mull over.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#16 |
Just thought I would throw in a simulation of proted and sealed box. A fair amount of extra output down to 16 Hz, the tuning frequency. Again, not advocating ported, just putting up some options.
#17 |
why not just buy an Aeolian Skinner pipe organ?
#18 | ||
dave
#19 |
Hi Kay,
Kay said: if you are looking for a more intelligent setup, read some papers: -------------------------------------------- Well I have read this paper. It is a very directed work, and seems somewhat sparse in providing enough rules or theories to follow the conclusions. One of the recommended configurations has you sitting practically top of the multiple subwoofers, which will have the flatest frequency response at the seating position. This may be true. In an earlier concept I proposed imbedding a subwoofer in the raised seating platform of the theater. (I mean there is all that space, ~25 cubic feet.) However I rejected it since such a configuration would seem to be very difficult integrate the subwoofer with the rest of speakers. Although for home theater, this may be fine, for music listening, it is considered important to have the sound generated from a uniform location. One of my goals in having a sealed array with an enormous sd, is to have a very musical bass setup. Setting up subs below or behind the listening position would seem to be counter to this end. James |
#20 |
Hi kelticwizard ,
kelticwizard chanted, in part: I was going to suggest he go in the other directiion-port these things for extra "oomph" ... He can always put the "convertible" sub's capped port hole in the back of the enclosure so nobody will see it. --------------------------------------- Well this is a very interesting notion. The reason I have been leaning towards sealed, is less distortion and a shallower drop off at the very lowest frequency. Also I am looking for tightness, and low boom. Musicality. I seriously doubt that I will require more boom, or that it would be desirable. However you bring up some very interesting ideas, on making it adjustable. I shall ponder this some more. James |
| Designing for on-wall/near-wall speaker placement | morbo | Multi-Way | 4 | 27th November 2010 05:52 PM |
| in-wall/on-wall speaker? (axiom w-22 clone?) | Scott_fx | Multi-Way | 0 | 22nd February 2007 03:08 AM |
| In-wall vs bookshelf spk flush with wall | darascott | Multi-Way | 3 | 1st October 2005 04:16 PM |
| In-wall subwoofer? | DIAR | Subwoofers | 14 | 9th March 2005 06:24 PM |
| In-wall NSB line array! | mazeroth | Multi-Way | 20 | 19th November 2004 05:22 PM |
| Page generated in 0.12086 seconds (83.24% PHP - 16.76% MySQL) with 11 queries |
