Threw together two new horn designs for the P.Audio E18ELF driver. One is ~1000L and gets around 104 dB/2.83V/m and the other is just over 550L and gets 102 dB/2.83V/m.
#2 |
Over 10:1 compression on an 18" driver? wow, I've gone against the conventional wisdom and have used up to 8:1 on an 8" driver, but never an 18.....
Planning on a cone shredding party? |
#3 |
Interesting you should say that.
I'm not an expert on this, but, at port tuning, a driver almost stops moving (need to shove a lot of power in to get it moving the same amount). 18" speakers get used in ported cabs all the time, and I've never heard of one shredding.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#4 |
That is not the same thing.
#5 |
in this case (offset driver) isn't s2 the compression area?
#6 |
Take this high comp ratio scenario and equate it to a 4th order( rear sealed) bandpass box. I see many 12" bandpass boxes built with a 4" port on the front chamber( 6 to 1 ratio). Is the reason the cone doesn't break because of the increased box volume(air compliance) in front of the driver?,as opposed to a smaller compression(front) chamber used on a tapped horn. Or is this still not the same situation?
JEREMY M_________________________________ I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ? Last edited by Top Shelf; 23rd October 2010 at 09:55 PM. Reason: more |
#7 |
#8 |
In a BR or BP the pressure have time to equalize and avoid high pressure bumps and vibrations.
In a horn with high CR you can get pockets with high pressure that will flex the cone, uneven loading due to taper will make it worse, this can make it rip. HOM is probably bad for it as well due to it's chessboard standing pattern. Water is a factor that will make it a lot easier to break. Sort of like an aluminum can. You can stand on it without a problem. But as soon as it flexes or get a ding it will rip and collapse. That's my theory at least. |
#9 | |
Through together some new designs for an Ande LB1560 15" driver to be used in banks of 4. Volume of 469L all up. |
| WTB 15" or 18" high qt. drivers | homemade | Swap Meet | 13 | 14th June 2010 07:15 PM |
| Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns | opc | Swap Meet | 6 | 1st May 2009 03:48 AM |
| Can I multiply an 18" folded horn cab by 0.8 for a 15"? | Optical | Subwoofers | 7 | 31st October 2004 04:37 AM |
| MJK Offset Driver simulation with PL-18 Help | JC Fardo | Multi-Way | 7 | 20th June 2004 06:28 PM |
| Page generated in 0.09625 seconds (82.66% PHP - 17.34% MySQL) with 11 queries |
