#81 |
#82 | |||
#83 |
Good try, but the effect of pipe and Helmholtz resonators is well-documented and in line in theory. The use of "reflectors" whose effectiveness is based on the assumption that "standing waves" occur in horns below 1/2L however, is not supported by any theory
#84 |
Brian I hope you understand I'm looking for the same thing, get the theory correct behind this...
It’s not that I don’t believe in the Helmholtz resonators as a practical solution, I certainly do! But it is still fixing the problem afterwards instead of fixing the problem itself (that's why we try to find the right theory to treat problems in future on a predictable way) Again Jbell says his “reflector” panel influence the area of 100 Hz. I see the length of the back panel is 29inch high. 29inch is = ¼ wavelengths of 116Hz. Is this again a coincidence? Or can we really influence a signal in a horn with "reflectors" (sorry have no better word yet) at ¼ wavelengths between two parallel walls? |
#85 | ||
.Quote:
I'm under the impression that reflectors in a normal horn are usually put there to improve midrange response. I don't think those are applicable to tapped horns, which have a passband that lies in the bass region. |
#86 |
Brian I’m not talking standing waves here...Altough... At the beginning and at the end of a standing wave it’s a zero point.. This means an amplification of the signal, right? Now, we see dips which means cancellation – out of fase.
Sanders himself seem to have influenced his Tham at 170Hz with reflectors. Jbell has given 2 examples of similar type. That it happens all around ¼ wavelength is not possible because of your theory of standing waves which is correct. But I’m talking about dips – out of fase signals. Standing waves are resulting in peaks not dips as you proved! Now go back to my example in room acoustics of measuring at a ¼ wavelength in a full wavelength standing wave. You will see that the signal of a standing wave, that is reflected from a wall, at ¼ of its full wavelength is out of fase (look for the chapter in you books about nodes and anti-nodes) So what theory tells you, you can’t influence a signal within a horn at ¼ wavelength??? And whitch of your theories says that anywhere in a horn, where two parallel surfaces ‘see’ each other, can't reflect a signal out of fase? This also means you are right, you can’t influence a full wavelength with a reflector but you can prevent parallel walls that develop ¼ wavelength – out of fase – signals by the use of reflectors… And no we are not talking about standing waves we are talking about cancellation as the result of ¼ wavelength reflected by walls... I'm not saying I'm right but I haven't seen any other explanation.... (yet) Last edited by Djim; 24th January 2011 at 02:05 AM. |
#87 |
Not correct. Check my graph. Look at what's happening at 700 Hz. That's 2*F for that particular horn/pipe geometry. And there's a null that's not predicted by HornResp.
And of course there's still the second issue to consider - the size of those reflectors - IMO they are simply too small to make any significant difference at low frequencies, reflection-wise. If they're making any difference, it's likely along what Danley and others have suggested - they're reducing the volume of the horn. Last edited by Brian Steele; 24th January 2011 at 02:18 AM. |
#88 |
See, you don’t get my point. Tell me if I’m wrong but any standing wave at it’s zero point can’t be out of fase. It is causing an out of fase signal as soon the standing wave is shifted from the original signal towards a ¼ of its full wavelength.
Secondly, The reflector doesn’t reflect the wavelength because its to small. It prevents the wall surface to develop a ¼ wavelength signal… |
#89 |
I gave you 2 examples.... I have more.... and not just from me.
I also played with reflectors on my big cabinet, and the cube... so I can give you #4, and #5 as well. and guess what fraction of a wave they all line up on? |
#90 | |
For the wavelengths we're talking about, I don't think it makes any difference. |
| 15" tapped horn with RCF | wood1y | Subwoofers | 114 | 1st October 2012 03:38 AM |
| Infinity BETA 15" sutable for a tapped horn? | Jimjim | Subwoofers | 13 | 13th September 2010 02:05 AM |
| P.O.C. #2 - Compact Tapped Horn | Brian Steele | Subwoofers | 17 | 18th September 2009 08:27 PM |
| Compact 15" sub - BMS or Precision Devices? | DIAR | Subwoofers | 7 | 4th January 2007 04:06 PM |
