#281 |
Hi BP1Fanatic,
The main input screen still displays the parameter values in metric units. The F6 function key can be used to show the equivalent Imperial value for a selected parameter, to 4 decimal places. Kind regards, David
www.hornresp.net |
#282 |
Thank you for such a great program David!
#283 |
will the celestion hdx 15 will work well in the tham 15??
#284 |
LF Cast Chassis / Ferrite - FTR15-4080HDX - Celestion - Guitar, Bass & Pro Audio Speakers
Should be OK.
Candidates for the Darwin Award should not read this author. |
#285 |
djk ur all right i sim its ok.
#286 |
Hi. I want to build tham-15. What revision is current, and what weight range to expect this box to be ?
| 15" tapped horn with RCF | wood1y | Subwoofers | 114 | 1st October 2012 03:38 AM |
| Infinity BETA 15" sutable for a tapped horn? | Jimjim | Subwoofers | 13 | 13th September 2010 02:05 AM |
| P.O.C. #2 - Compact Tapped Horn | Brian Steele | Subwoofers | 17 | 18th September 2009 08:27 PM |
| Compact 15" sub - BMS or Precision Devices? | DIAR | Subwoofers | 7 | 4th January 2007 04:06 PM |
