#271 |
The only valid point I have seen is about the fence guide being in Imperial units.
If you change blades you would also need to reset the zero on the fence. 18mm is 0.70866, while these-days 3/4" is actually 23/32 or 0.71875 This can be a big deal if making rabbets or dadoes.
Candidates for the Darwin Award should not read this author. Last edited by djk; 31st December 2012 at 05:18 AM. |
#272 |
#273 | |
Long time since being here. I will give the conversion a try in Solidworks, it might be that when I change the dimensions of the material I can make an imperial version very easily. As Schwarzenegger would say "I'll be back !" |
#274 |
Regards, Dan |
#275 |
Where do you find that tape Dan?
Aggressively Passive |
#276 |
The text above the pic contains the link
Regards, Dan |
#277 |
Younger eyes needed I think........
Thanks, Dave
#278 |
To enter a length, area or volume value in Imperial inch or foot units, press F6 in edit mode when the relevant input parameter has the focus.
Kind regards, David
www.hornresp.net |
#279 |
Does the main screen still display in cm? I'm on my cellphone.
#280 |
great feature.
i sometimes use google to find a conversion. this is much easyer,since hr is always running on pc. tnx again david
one good thing about music ,when it hit you feel no pain. so hit me with music.
| 15" tapped horn with RCF | wood1y | Subwoofers | 114 | 1st October 2012 03:38 AM |
| Infinity BETA 15" sutable for a tapped horn? | Jimjim | Subwoofers | 13 | 13th September 2010 02:05 AM |
| P.O.C. #2 - Compact Tapped Horn | Brian Steele | Subwoofers | 17 | 18th September 2009 08:27 PM |
| Compact 15" sub - BMS or Precision Devices? | DIAR | Subwoofers | 7 | 4th January 2007 04:06 PM |
