THAM15 - a compact 15" tapped horn
Old 9th September 2012, 12:26 PM   #261
MagicJohansson is offline MagicJohansson  Finland
Originally Posted by epa View Post
hi magic
nice job on the subs.
seems a solid bild with a nice finish
also like the placings of the handles ,and speakons.
only thing i dont like is the mesh grill.
why not use stretch metal?
Thank You all for Your response, nice to hear.
@epa, yes, You are right, the grills were a last minute solution, gig coming up and nothing else on hand. They will eventually be replaced (sometime )
Old 27th December 2012, 10:06 PM   #262
YogiNC is offline YogiNC  United States
Are these plans available in english measurements?
Old 29th December 2012, 03:08 PM   #263
djk is offline djk
R.I.P
djk's Avatar
American Presto 5/8" x 12'/3.6mm Tape Measure (SAE/Metric) at Arizona Tools
Stanley 5m/16 ft. x 3/4 in. Tape Rule Metric and SAE-30-496 at The Home Depot
$5
Heavy Duty 16 ft x 3 4" English Metric Tape Measure Measuring 490cm mm Foot | eBay
Candidates for the Darwin Award should not read this author.
Old 29th December 2012, 05:26 PM   #264
PASC is offline PASC  Brazil
Millimeters conversion calculators, tables and forumas
PASC
Old 29th December 2012, 07:14 PM   #265
Both of you obviously missed the point of my question. I can do the conversions, it's just a PITA to convert so many different measurement points in a cabinet this complex. Add to that a table saw that is highly accurate with ENGLISH measurements on the tape along the fence rail. For an old fogie like myself (59 years without the metric system) who is an accomplished woodworker, learning that trick is just too hard for this old dog. It's hard enough doing the mental math when reading posts.
Old 29th December 2012, 11:27 PM   #266
djk is offline djk
R.I.P
djk's Avatar
"Both of you obviously missed the point of my question. "
That you're lazy?
So do you plan on using 3/4" or 18mm or what?
They all require some adjustment to the plan. Details like this are best worked out by the builder, not the designer.
Old 29th December 2012, 11:59 PM   #267
Lazy, ummm NO! I have no doubt that if these designs were in english vs. metric that many would request it be the other way around. Besides, I'm going for the SS15, and that design is ummm in english units. Since there are so many of both sides I would just think that is would be a courteous thing to have plans in both units of measure.
Old 30th December 2012, 08:59 PM   #268
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
I have produced cabinet plans in metric and imperial equivalents before when requested, but only because the CAD software made it easy. The conversion was done with a click of a few buttons. The actual design process on the other hand can take days - months - years..........
For most of us unit conversion would be a long winded process, and the effort involved would be the same regardless of who did it. Maybe that is part of the D I Y ethos. DO IT (for) YOURSELF, and then maybe document and share.
Regards Xoc1
Old 31st December 2012, 04:22 AM   #269
djk is offline djk
R.I.P
djk's Avatar
" Since there are so many of both sides I would just think that is would be a courteous thing to have plans in both units of measure. "
And what about the differences in what constitutes 18mm or 3/4" plywood?
Old 31st December 2012, 04:52 AM   #270
Djim is offline Djim  Netherlands
THAM15 - a compact 15" tapped hornHide this!Advertise here!
15" tapped horn with RCF wood1y Subwoofers 143 22nd April 2017 01:36 PM
Infinity BETA 15" sutable for a tapped horn? Jimjim Subwoofers 13 13th September 2010 02:05 AM
P.O.C. #2 - Compact Tapped Horn Brian Steele Subwoofers 17 18th September 2009 08:27 PM
Compact 15" sub - BMS or Precision Devices? DIAR Subwoofers 7 4th January 2007 04:06 PM
