THAM15 - a compact 15" tapped horn
Old 9th January 2012, 03:14 PM   #251
$$Maan is offline $$Maan  Denmark
@epa: Do you have a plan for your design?
"it was something like 60 wide*90 high*70 deep cm "
I have birch ply cut up for 2 boxes with these dimensions, might as well use it!
Old 22nd April 2012, 08:33 PM   #252
MagicJohansson is offline MagicJohansson  Finland
Hi guys and gals
I finally pulled the trigger and started building 2 THAM15's after reading such good comments on them both here and on other forums.
Here are some pics from the build:
This is a screencapture from Solidworks
This is the phase where I am now
http://www.fellows.fi/pics/THAM15_1.jpg
http://www.fellows.fi/pics/THAM15_2.jpg
http://www.fellows.fi/pics/THAM15_3.jpg
Old 22nd June 2012, 04:35 AM   #253
Jason in SD is offline Jason in SD  United States
Hello, This is my first post and my first attempt at Hornresponse. Although I cannot figure out how to capture the spl plot, I am seeing a very similar plot to the 15TBX100 when modeling the Celestion FTR15 4080HDX in the Tham15. Can anyone confirm or deny my findings? (realizing this is a dead thread and hearing crickets chirping) Thanks
Old 8th September 2012, 06:53 AM   #254
Hi again, guys
Sorry for not posting this earlier, but here goes.
Here a detail-pic from the inside with the reflectors, bracing and handles
Both of them together
A detail pic of the finish using Warnex structure paint with a roller
And finally the first test outdoors together with our EAW KF300e tops
We were running the subs from a bridged Crown XTI4000, limited to 100V, ie about 2600W for the pair and when going full out we could watch the pebbles on the ground dancing :-)
The sound was very tight and clean, and if You stand in front of them and try to talk Your voice will be modulated, feels quite interesting. We did not do any measurements other than using ears and stomach but the consensus was that they really deliver in the range a rockband needs, ie the bassguitar fundamentals are stunning, the kickdrum in the 80 Hz-range is really kicking and they can go up into 100-150 Hz if needed.
We have now gigged with this setup the whole summer and the expectations were fully met.
The deliver that tight, clean sound that we want, the dB/m3 is exceptional, the handling worked out perfect with the wheels and handles and we are just happy with the build.
Old 8th September 2012, 01:48 PM   #255
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Excellent work Magic
Dan
Old 8th September 2012, 02:47 PM   #256
tb46 is offline tb46  United States
Hi MagicJohansson,
Thanks for the rendering and the pictures. Very nice job - well done.
Oliver
Old 8th September 2012, 08:30 PM   #257
Samuel Jayaraj is offline Samuel Jayaraj  India
MagicJohansson, did you use the LAB15 drivers?
Sam
Old 8th September 2012, 08:42 PM   #258
No, I used the B&C 15PS100. The driver recommended by Martinsson is the B&C 15TX100 but after lots of simulations and a long look at the pricetab I decided to use the cheaper PS-model since the only real differences are (in this order) price (cheaper), power handling (a little less but still 1 kW) and a little less group delay.
Old 9th September 2012, 11:24 AM   #259
Thanks. That is pleasant info.
Sam
Old 9th September 2012, 11:57 AM   #260
epa is offline epa  Netherlands
hi magic
nice job on the subs.
seems a solid bild with a nice finish
also like the placings of the handles ,and speakons.
only thing i dont like is the mesh grill.
why not use stretch metal?
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
THAM15 - a compact 15" tapped hornHide this!Advertise here!
15" tapped horn with RCF wood1y Subwoofers 143 22nd April 2017 01:36 PM
Infinity BETA 15" sutable for a tapped horn? Jimjim Subwoofers 13 13th September 2010 02:05 AM
P.O.C. #2 - Compact Tapped Horn Brian Steele Subwoofers 17 18th September 2009 08:27 PM
Compact 15" sub - BMS or Precision Devices? DIAR Subwoofers 7 4th January 2007 04:06 PM
