Hi folks.
I'm searching around for small sonosubs. I think this will be one of my next projects. Aim is to build 2 small tubes. 150mm with 6,5", 800mm long will give 15 liters. Need a little help with input about drivers and tuning. I have looked at Tangband's 6,5" W6-1139SI. Amp will be my 100w Rotel and plan is to use passive lowpass at 150Hz. Any reason why i should not do this? Of course WAF is a major factor here ![]() Georg |
#2 |
Greets!
Well, 15 L will get you down into the lower 30s, so OK for most music, but this driver's mass:compliance ratio doesn't safely allow horizontal loading due to excessive sag, so the tubes would have to be laid down. With a 150 Hz XO it will be necessary to keep the 'subs' close to the mains, compromising room placement flexibility. Ideally you want enough power to ensure there's no amp clipping or ~300 W for this driver, so hope it has a benign sounding protection circuit if you occasionally like to 'crank it up' till the woofers are beginning to audibly distort. I'm guessing that a pair of 80 cm long tubes arrayed across the room is low WAF. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
#4 |
You're welcome!
Good question! The only low Fs drivers I'm familiar with that are suitable for down firing are those specifically designed for it and relatively expensive 12" or larger car audio 'sub' woofers that typically require a way more power than you have to be worth the effort. A T-TQWT OTOH will position the driver upright enough, but requires you to make a tall box. GM
| 15" "SonoSub" idea. Comments appreciated! | odysseybmx414 | Subwoofers | 7 | 16th October 2010 05:32 PM |
| 15" Sonosub Kit UK Group Buy | jimbo1968 | Group Buys | 14 | 29th May 2007 10:31 AM |
| 15" sonosub kit for UK - group buy started | jimbo1968 | Subwoofers | 0 | 1st January 2007 02:27 PM |
| twin 15" sonosub | cnctooltek | Subwoofers | 5 | 5th April 2006 02:53 PM |
| 8" Sonosub help needed | julianboudville | Subwoofers | 12 | 8th October 2004 03:05 AM |
| Page generated in 0.07859 seconds (72.09% PHP - 27.91% MySQL) with 10 queries |
