Hi
I have a couple of Eminence Delta 15LF's taken from a pair of bass horns. I plan to make a subwoofer that can provide a good amount of bass down to around 35-40 Hz. What kind of enclosure would be preferable for this? When put into winISD the size of the box required is generally pretty large. Perhaps electronic equalisation is required to get a decent response down to this level (it is unlikely that they will need to be used at full power 2 x 500w RMS) Cheers |
#2 |
A sealed box with a lot of eq would work. Apart from that, PA drivers generally seem to need big boxes.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#3 |
The Delta 15LF only has an xmax of 4.8mm it will not take anything like its power rating at the low frequencies you want.
The Eminence site shows a single driver in a 165 litre cabinet limited to 175W with a steep hi-pass set at 35Hz http://www.eminence-speaker.com/pdf/cab-delta-15lfa.pdf. Xmech is quite large, I would think that a manifold type reflex cabinet would be good. The 2 opposing drivers help to reduce distortion when xmax is exceeded. manifold subwoofer or labhorn? |
#4 |
Iso-braric loading could be an option, to reduce the cabinet size...
#5 |
How large can the cabinet be?
Best regards Johan
Impossibilities we do immediatly, miracles take slightly longer. |
#6 |
Using the isobaric arrangement will reduce the necessary volume, but, it will also reduce the available SPL. I have (mis-) used speakers before in a sonotube isobaric bandpass with some success. Regards,
Oliver |
| Eminence Delta Pro 18A - is it what it claims to be? | Spasticteapot | Subwoofers | 10 | 2nd May 2010 09:08 AM |
| FE207E + Eminence Delta 12 LF | larkinrulez | Full Range | 22 | 18th January 2009 05:28 PM |
| Eminence Delta B 8 inch driver | BudP | Multi-Way | 1 | 29th April 2008 11:56 AM |
| 3 way project - Morel 110 - PHL 1120 - Eminence Kappa Pro 15LF-2 | Branwell | Multi-Way | 19 | 14th July 2005 02:21 PM |
| Eminence Kappa Pro 15LF-2 vs Peerless 12" XLS | Branwell | Multi-Way | 5 | 26th July 2004 10:43 AM |
| Page generated in 0.08717 seconds (76.11% PHP - 23.89% MySQL) with 11 queries |
