i got two image dynamics idmax 12's lying around collecting dust. their pretty efficient and have good xmax. i would like to design a tap horn for these. are they suitable for a tap horn. i know there's plenty of different drivers to go with... i just wanna use these drivers. some one help?
http://www.imagedynamicsusa.com/manu...DMax12D4V3.pdf IMP 2 / 8ohms Nominal Impedance Re 3.0/ 6.0 Ohms DC Resistance Fs 20Hz Resonant frequency Qes .40 Electrical “Q” Qms 2.1 Mechanical“Q” Qts .34 Total “ Q” Vas 5.81 cuft (165 liters) Equivalent volume Xmax 24.9mm One way linear Sd 545 cm2 ConeArea Spl 93.1dB/88 dB 1w/1mG.P./SPLi Pwr 1000 Watts RMS POWER SPECIFICATIONSSUBJECTTOCHANGEORIMPROVEMENTWITHOUTN OTICE SPEAKER SPECIFICATIONS Speakerdisplacement0.12cuft. BOTHVOICECOILSMUSTBE USEDATALLTIMES DIMENSIONS 12.50“ 8.25“ 11.0“ ENCLOSURESPECIFICATIONS LARGE NORMAL SMALL SEALED VOLUMESGROSS PORTEDVOLUMESGROSS InfiniteBaffle 1.3cu.ft. 1.0cu.ft. -3dbIncar\Freespace 10Hz\40Hz 10Hz\41hz 14Hz\48hz 2.72 2.55 2.0 PortedFrequency 25hz 28hz 32hz PortDimensions 4” I.D.X17.5”long -3dbInCar\Freespace 16hz\26hz 18hz\28hz 20hz\34hz cu.ft. cu.ft. cu.ft. 4” I.D.X15”long 4” I.D.X15”long |
#2 |
Sure, assuming the specs are reasonably accurate and you don't mind it being relatively huge with just one driver (311+ L). It will play loud down to 20 Hz though if the Xmax is for real.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
definitely not the ideal TH candidate... however here's a guess for you.
My assumption was this was for home theater, not in car... so here's an under 300liter 28hz TH that's good xmax wise down to 20hz and 500watts. Room gain should start kicking in where the TH starts falling off to get a nice flat bottom end response. One of these should get you more than THX levels at seating position, a pair should be impressive. Fold it like a TH spud, make a pair of them the 2nd row riser in your theater. |
#4 | |
in a small ball park... what will one of those subs do spl wise? 120... 130? i really wanna use both of these subs. if i use 2 in the box... the box will be too large? |
#5 |
Before getting serious, you need to identify where in the room you want this, and how much space you really have.
A pair of 12" drivers in 300liter cabinets is generally not wife approved the lower 48 states..... This is just a quick sim (2pi, aka outdoors, 0.5pi, aka in a room corner) to show that 'something' is possible. Last edited by jbell; 30th September 2010 at 02:11 PM. |
#6 | |
49 - for the 16th time
![]() Not to mention hearing loss!!!
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod |
#7 | |
is two tap horns built tall and skinny doable? i kinda like the way a tower sub looks. my room is 10(h) X 16(w) X 24(long |
#8 |
140 dB at Home? thread. At what BW? IMO SQ is totally forgotten in the equations. FYI: b |
#9 |
Picture update (revised)
b |
#10 |
man... my internet was down all weekend. soo... should i go for the dual idmax 12" taphorns?
| Horn Design | MurF | Multi-Way | 1 | 30th June 2008 02:56 PM |
| Horn design? | lemans23 | Multi-Way | 12 | 28th March 2007 04:12 AM |
| how to go from horn response to a folded bass horn design? | paulspencer | Subwoofers | 8 | 4th November 2005 10:44 PM |
| new horn design | exurbia | Multi-Way | 3 | 2nd July 2002 12:59 PM |
| Page generated in 0.10282 seconds (83.71% PHP - 16.29% MySQL) with 11 queries |
