Hi Guys,
what is the optimum driver's T/S parameter if I want to build TL sub that can go as low as 25Hz with ample gain. Chris |
#2 |
Greets!
'Optimum' is a moving target that's dependent on the needs of the app, but from a technical POV, a max flat impedance is the optimum, so Fs/Qts will define its Fp. From this we see that to get down to 25 Hz with authority will require a <25 Hz Fs driver with a Qts up to ~1.0 and preferably around 0.7 or a bit less depending on the driver's Fs and any room loading effect. Also, with larger pipes the driver's Vas needs to be enough to fill it up, a real problem with many drivers today that are designed to work in teeny-tiny cabs. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
Thank's GM,
I already built TL sub back in 2006 with not so good driver for TL, but the result is affordable good for my ear. Now, I have time to replace it , but this time I want better result by carefully choosing a driver that is fit with TL design. So for my need, the driver should be: 1. Fs<25Hz , is it correct, lower is better? 2. Qts<1 , preferable 0.7 , what if lower than 0.7? is there any other T/S parameter to be considered? Vas? Bl? Chris. |
#4 |
You're welcome!
Right, you ideally want Fs to be at least as low as the lowest you want it to go and if it has enough power handling, then a little lower. Just like with a typical vented alignment, the lower Qts is, the higher its F3 will be if not EQ'd. As I noted, low tuned TLs with any decent output are large, so the driver's Vas needs to be high enough to 'fill up' the TL. If it won't, then a hybrid is required, i.e. place the driver in a box and add large/long vent. Another way is to use a reverse tapered TL (TQWT). For instance, the Exodus Audio Shiva X2 has a ~21.3 Hz Fs, but only a 97.12 L Vas, so tuned to 21.3 Hz the TL's area isn't large enough to mount the driver and with a ~0.39 Qts, yields a ~26 Hz F3 in half space, though of course it will be considerably higher if stuffed. A large enough TQWT to fit the driver comfortably in will be ~20% larger though. GM
#5 |
Thank's GM,
ok, so Fs and Qts are the important parameter for TL, as we know, today most driver Vas is small, so what is the minimum Vas that still work with my criteria ? How about the box? What is the best configuration for my sub? ML TQWT or do you have any other suggestion? and what is the best position for the driver in the box, at the end of the box or offseted (how far?)? Chris. |
#6 |
You're welcome!
Unfortunately, you have to design it first to find out what each driver 'wants' in the way of acoustic impedance loading. Now that MJK has developed a relatively simple 'classic' TL designer complete with driver offset suggestions that another DIYer turned into an Excel SS to make it even quicker/easier, it doesn't take long to find out if the driver will comfortably fit (typically 3-4x Sd) and software to fine tune it if need be using an old MathCad demo available from his site: Quarter Wavelength Loudspeaker Design WRT driving position, for a (sub) woofer that's limited to ~ two octaves, i.e. its HF limit is ~ 1WL away from Fp, then end loading is best since it yields the maximum gain; otherwise, offset is usually best overall since it trades max gain down low for a smoother response over a wider BW with less stuffing density. For 25 Hz then, 25*2^2 = ~100 Hz upper usable limit for end loaded and by 'end loaded' I mean it can be mounted either on the top plate or end of a side plate. GM
#7 |
Thank's GM,
yes , it is a lot easier using Excell SS first and then throw the result to MJK mathcad for detailing. |
#8 |
#9 |
thank's bjorno
#10 |
"you ideally want Fs to be at least as low as the lowest you want it to go and if it has enough power handling, then a little lower."
What happen if Fs > F3, say F3=25Hz and Fs=30Hz ? Chris. |
| Dampening a driver's basket? | enigmaticEntity. | Multi-Way | 14 | 2nd January 2010 07:49 AM |
| How can I find a driver's specs | fin1bxn | Multi-Way | 0 | 24th January 2007 01:36 PM |
| Davis Driver's Any one used ? | jleaman | Multi-Way | 9 | 8th April 2006 09:32 AM |
| Optimum TL for this driver? (GM might want to take a look) | mr_push_pull | Multi-Way | 1 | 3rd June 2005 08:23 PM |
| driver's acoustical center | joz | Multi-Way | 17 | 25th May 2003 07:08 AM |
| Page generated in 0.10913 seconds (82.28% PHP - 17.72% MySQL) with 11 queries |
