Any 15" DVC pro speakers out there?
Old 17th September 2010, 03:30 PM   #1
mr. doom is offline mr. doom  United States
Default Any 15" DVC pro speakers out there?
I am looking for a high efficiency (98db+) DVC driver for a project. I know JBL and maybe Carvin had a sub cabinet loaded with DVC drivers but have not found a source for the raw drivers. Neo motors would be great but cheap would be better.
Old 17th September 2010, 05:15 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
DVC pro driver? Not too common I wouldn't think. Little call for it. If you find one, please post it, It would be interesting to see. What do you plan for it?
planet10 needs your help:
Let's help Ruth and Dave
Old 13th January 2011, 08:39 PM   #3
Still in search of a DVC driver to run off a battery powered class-d amp and need a single unit that can draw the most "juice" out of a small T-amp. Dual 4ohm coils and high efficiency from 50-100hz would be perfect. Should probably post this in the subwoofer forum.
Old 13th January 2011, 08:41 PM   #4
Speakerholic
Cal Weldon's Avatar
Moved to Woofers.
Old 13th January 2011, 09:08 PM   #5
Default Thanks.
Originally Posted by Cal Weldon View Post
Moved to Woofers.
With all the new chip amps on the market I do not know why more efficient DVC drivers are not available for DIY. Most pro audio powered boxes have gone to 4ohm drivers in order to get 1000w out of class D amps.
Old 14th January 2011, 01:29 PM   #6
epa is offline epa  Netherlands
only now an 18" dvc but is dual 8 ohm
Ps18/300DC
why not take 2 *12"4 ohm drivers?
Old 22nd January 2011, 06:56 PM   #7
stera66 is offline stera66  Serbia
I heard of modified Eminence Kappa 10" to DVC 2x8 OHM.
Second coil is done by repair shop. The person who build sub is fully satisfied and I'm considering to build this sub also with Kappa 2x8 ohm.
Just realized that you are looking for 15" -belive that this can be done with 15" also.
Old 22nd January 2011, 07:03 PM   #8
Andrew Eckhardt is offline Andrew Eckhardt  United States
Power level summation is not the most efficient way to go about it. You'd be better off going with a single power amplifier and mixing to mono at signal level, especially if there is not enough distance between the HF drivers to provide any sort of stereo image at the "listening postion" anyway.
Old 31st January 2011, 12:45 AM   #9
OscarS is offline OscarS  United States
every now and then, you can find some Cerwin-Vega Strokers. They were released for car-audio in the mid-90s, but they are "pro-audio" through and through. I just recently picked up a couple for $200, dual 2-ohm coils. The nice thing is that recone kits are available in single and dual coil configurations.
here they are, amongst the rest in my collection:
Old 31st January 2011, 03:26 PM   #10
doug20 is offline doug20  United States
Why DVC and not SVC??
Any 15" DVC pro speakers out there?Hide this!Advertise here!
Dayton 295-190 15" DVC RSBosma Subwoofers 4 18th February 2007 01:59 AM
Peerless XXLS 12" DVC (830837)- replacement for PE Dayton 12" DVC 295-185? tktran Subwoofers 2 14th August 2005 02:04 PM
Subwoofer guide posted, Sealed Dayton 15" DVC wigginjs Subwoofers 2 4th November 2004 05:39 AM
Tempest 15" or Dayton 15" DVC Sub? longblock454 Subwoofers 1 31st January 2004 06:24 AM
cheap dayton 15" DVC griff Swap Meet 0 3rd April 2002 01:56 AM
