#11 | |
The sim shows 115 Hz/700 W/10 mm Xmax/2pi and some say in reality it will be higher if I did the alignment correctly and the driver can handle that much power at low thermal distortion with a ~2.5:1 CR, which I seriously doubt. Still, it should easily drown out a similar size BR all the way up at least into the 90s. Don't know, the Infinity site only lists it as a dual VC driver with the somewhat different spec 15X being a single VC. For a given bulk, Fp AFAIK, though it can be made to go lower, bigger since its LF cut-off is down around 2.7 Hz, though with only 10 mm Xmax, not wise to tune it too low with just a single driver. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#12 | |
Yes, you make me wonder if I should quit listing it. Dual 4 ohm VCs in series per the linked owner's manual. Mine implies a 22-23 Hz F3, though I expect (hope?) based on others sim Vs measured that it would be around 20 Hz based on the driver's ~94 dB efficiency. I see I made a typo, the sim is ~335 L.. A dual is ~539 L, though of course in each case they can be expanded somewhat. From this it's pretty obvious we have different ideas as to what constitutes a DTS concept and until I can get one built/measured I don't know if I have a clue or not, but the power sims are encouraging since I'm getting as much or more SPL in less/same bulk than with some other layouts. GM PS - I used his too except for a higher inductance, though I assume they're not very accurate, probably rendering all our musings mostly moot.
#13 |
Hi GM,
Thanks for the explanations. I think there is a lot of room for what may be a DTS concept :-). I like to use a coupling chamber between driver(s) and throat, that's one obvious deviation. The total volume is so dependend upon the bottom cut-off point and shape, it's very hard to compare except model next to model, and then one would still have to build and measure. Oh well. Regards,
Oliver |
#14 |
Greets!
You're welcome! Yeah, with one exception, for me it's just a catch-all for ones with obvious 1/4 WL stubs. GM
| Dual 8" tapped horn = TH-SPUD | geitmans | Subwoofers | 119 | 1st January 2012 08:14 PM |
| 15" tapped horn with RCF | wood1y | Subwoofers | 113 | 24th April 2011 01:03 AM |
| TH-Micro - a 6,5" tapped horn | martinsson | Subwoofers | 27 | 8th February 2011 02:01 PM |
| 10" 15hz Tapped Horn | jblauvelt | Subwoofers | 11 | 7th January 2011 02:36 AM |
| Page generated in 0.07926 seconds (77.35% PHP - 22.65% MySQL) with 11 queries |
