If I put 4 of these speakers in a sealed box, What should the volume of the box be?
The box is stuffed with fiberglass. Each speaker will be driven by an individual 100 watt rms amplifier. Should I use a single voice coil or put them in series or parallel? 175W RMS Dual 4 Ohms Mounting Depth: 4.5" Mounting Hole Diameter: 7.3" Electrical Q Value -Qes: 0.38 Mechanical Q Value -Qms: 4.21 Total Speaker Q Value -Qts: 0.34 Free Air Resonance -Fs: 22.8 Hz Equivalent Compliance -Vas: 27.1 liters = 0.957027468 cu. feet One-Way, Linear Excursion -Xmax: 12 mm Efficiency -SPL 1W/1m: 81.2 dB SPL Effective Piston Area -Sd: 195 cm^2 DC Resistance -Re: 3.2 ohm Force Factor -Bl: 15.4 Thank-you, Russell |
#2 |
as a rule, you NEVER run a single voicecoil in a DVC woofer; they both need juice!
Your (classD?) 4 x 100w probably likes 8 Ohms, not 2 Ohm (few do!) so definitely wire the VCs in series. A sealed box with Qtc = 0.7 is most common and that volume would be 32.61 liters from WinISD online: LinearTeam Notice the ported box would give a low end response (F -3db) of 30Hz, while the (1/2 vol.) sealed will only go to 50Hz. Some do like the sound of a sealed box though. Also many prefer different sealed box Qtc; lower for faster transients, higher (more common) for better group delay etc. |
#3 | |
The TS you have submitted is for the coils in series and is IMO preferred. I would put 4 of these drivers in a box of ~net volume of 35 L if the speaker are placed away from walls or if are to be used in a car. If close to wall(s) I suggest a volume of 60L or more. If you are aiming at a sub system for HT (music only too) I would design a dual driver ~56L T-TQWT and two closed boxes (~16L/box) using your 4 drivers. b |
#4 |
Whether the individual speaker's coil pairs should be series or parallel on each amplifier depends mainly on the design of the amplifier, because, you'll be potentially determining a difference in output power output limit by a factor of 4. If the amplifiers are designed for a 2 Ohm load you'll be wasting a lot of amplifier with an 8 Ohm load. If the amplifiers are designed for an 8 ohm load then you'll probably get the best fidelity and possibly close to maximum output power with an 8 ohm load. The response of the speakers itself will be very similar either way.
| Hypothetical question on multiple Small woofers vs few larger woofers | navin | Multi-Way | 38 | 7th June 2010 11:17 AM |
| Mounting Multiple Woofers | mikje | Multi-Way | 6 | 19th December 2008 03:03 PM |
| FS: pair of new Lambda TD-15S sealed box woofers | taloyd | Swap Meet | 2 | 5th June 2006 02:45 AM |
| Multiple bass drivers in single sealed enclosure... | richardkrol | Multi-Way | 14 | 5th March 2004 02:34 AM |
| Ciare Nd-magnet PA woofers for sealed box home subwoofer? | capslock | Subwoofers | 1 | 22nd September 2002 01:23 AM |
| Page generated in 0.08186 seconds (72.07% PHP - 27.93% MySQL) with 11 queries |
