What enclosure type for this cheap trick driver? What enclosure type for this cheap trick driver? - diyAudio
Old 6th September 2010, 09:07 AM   #1
Ibex is offline Ibex  Austria
Default What enclosure type for this cheap trick driver?
Cheers!
I've got a punch of these low price 5" bass drivers and I want to design a suitable sub for these cheap woofers.
Do you have any recommendations for me referring to the enclosure type to get a serious low end out of these 5"?
Here are the TSP:
fs = 72,6 Hz
Re = 7,5 Ohm
Qes = 0,41
Qms = 2,37
Qts = 0,35
Vas = 5,25 L
Cms = 0,47 mm/N
Mms = 10,13 g
Sd = 88 cm²
BxL = 9,2 N/A
Rms = 1,9 kg/s
Le = 1,77 mH
I was thinking of some type of bose 8th order bandpass style would do the job, but I would prefer something hornloaded ( i.e. TH/RLH or compound horn style).
Thx in advance for your help!
gzg
Old 6th September 2010, 10:54 AM   #2
chris661 is offline chris661  United Kingdom
chris661's Avatar
Horn loading might work (not my area of expertise), but a sealed box with eq would work, especially if you have a lot of the drivers. What are the size limitations?
My work: www.grimshawaudio.com
Old 6th September 2010, 03:34 PM   #3
zobsky is offline zobsky  India
zobsky's Avatar
Here's a tapped horn design, and tweak in horn resp as desired. The throat size is too small, so my suggestion would be to use a multiple of drivers (say 2), and increase all the cross sectional areas by that number.
I don't know what X max is but I managed to drag response down to 40 Hz (about an octave below driver Fs) where you're Xmax limited to 5 watt input per driver . SPL at that point is about 105 - 110 db, with room gain flattening out the response.
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 6th September 2010, 04:02 PM   #4
GM is offline GM  United States
GM's Avatar
Greets!
It will take ten drivers to = a 15", though with only 2-3 mm of usable excursion at best and with a ~15 Hz low cutoff capability (FL) you'll have to define 'serious' to see if you have enough drivers to go low with any authority.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 6th September 2010, 07:24 PM   #5
Thank you for your replies!
Of course, my intension was to use multiple drivers in a single enclosure, let's say about 8 pieces. I was thinking of an push-pull arrangement as well, like in danley's DTS-10, to avoid linear harmonic distortion caused by the motor and to get a better cone control due to less excursion.
To get the smallest excursion as possible I thought a TH design would be the best choice. What do you think?
Unfortunately I don't know the Xmax of the driver and I realy don't know what the driver is capable to do. Power ratings are 90W continous/180W programm.
What about these bose type woofers in the acoustimas sub modul? I always thought that they are small and offer a small Xmax as well or am I wrong?
That's why I first was thinking to suit my 5" drivers in a bose style bandpass enclosure... would you disadvise me to design something similar?
Size limitations of the whole enclosure would be about ~500L brutto.
Old 6th September 2010, 07:36 PM   #6
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
In that case, that tapped horn scaled to utilise 8 drivers might be nice
Old 6th September 2010, 09:06 PM   #7
tb46 is offline tb46  United States
Default Octet Tapped Horn?
Here is a tapped horn with throat chamber coupled to horn.
Oliver
Old 7th September 2010, 11:47 AM   #8
Wow, the TH design looks quiet good!
I got the chance to take measurements of the voice coil and the pole plate to caculate the linear excursion of the driver. Here you are:
Magnetic Gap Depth = 5.25mm
Voice Coile Winding Depth = 10.5mm
I would assume that Xmax would be 2.5mm in one direction...?
Would be interesting to see where the output of the TH is limited by the excursion.
Old 7th September 2010, 11:51 AM   #9
why did you implement a chamber between the driver and the throat?
is there a reason to port the chamber with an offset into the horn and not at the beginning of the TH?
Old 7th September 2010, 02:16 PM   #10
Hi Ibex,
I added the throat chamber as an option, and to minimize the L12 distance. Shortening L12 strongly affects the impulse response. Without knowing the rough external dimensions desired this looked like a reasonable first stab at a simulation.
As to the Xmax, even if you add half the gap depth you don't come anywhere close to what you would like to see in a driver build for subwoofer duty (see Post #4 by GM).
Oliver
What enclosure type for this cheap trick driver?Hide this!Advertise here!
finished Cheap Trick CT 227 with Aurasound NS3-193-8A Ralphono Full Range 5 31st May 2007 05:27 PM
What type of enclosure?? e-side Multi-Way 5 25th December 2005 06:17 PM
Plans for Visaton Cheap Trick 142 mr_push_pull Multi-Way 13 3rd July 2004 01:09 PM
Q:cheap trick 142 Tomac Multi-Way 0 21st December 2003 07:18 PM
Copyright ©1999-2017 diyAudio
