#21 | |
Here's a bunch of random observations: 1) The Fluke 77 (which generation?) like most meters is not hyper-accurate. But 0.8 is WAY too low for speaker specified as 4 ohms and 8 ohms. 2) Do the speakers play? If not, there is a short, but the windings didn't come off the coil. If they do play, maybe a partial short. Unusual, but possible. 3) Transformer: interesting, but I would think quite lossy. The spec sheet at http://forums.klipsch.com/forums/sto...ContraBass.pdf shows 3 ohms nominal-due to loading, you can't go by DCR too much. 3b) That's not what these subs need anyway, these subs are just defective. 4) Wiring speakers in series is never an optimal idea. The voltage never divides evenly. Yes it will make sound, but not the best solution. 4b) That's not what these subs need anyway, these subs are just defective. And finally, 5) These subs are just defective. |
| FS: 8 ohm Diatone drivers | whiteSE | Swap Meet | 1 | 16th March 2010 02:51 PM |
| LM3876 and 4-ohm drivers | astrodog | Chip Amps | 15 | 2nd July 2008 11:22 PM |
| 16 ohm drivers? | morbo | Full Range | 24 | 16th November 2004 04:58 AM |
| What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? | The Paulinator | Multi-Way | 9 | 11th May 2004 07:04 PM |
| 16 ohm drivers | markkanof | Multi-Way | 11 | 4th May 2004 04:30 AM |
| Page generated in 0.05722 seconds (72.70% PHP - 27.30% MySQL) with 10 queries |
