Small footprint SUB using multiple small drivers
Old 25th August 2010, 09:28 PM   #1
FredrikC is offline FredrikC  Norway
Default Small footprint SUB using multiple small drivers
Hi there! I'm brand new to DIY and currently reading everything I can find on the subject of Subwoofer building. I'm from Norway so I use the metric system in my posts....
I currently own a pair of small monitors that I would like to place on a pair of tall small footprint subs.
The dimensions should be w:20*cm d:26cm hight:65cm. This should equal somwhere between 25-30l without any foam/isolation...
I want musicality and slam rather than the very deepest bass. It's perfectly OK if it rolls of around 30hz. The monitors take care of the mids, so I need drivers that can handle something like 30-150-200hz...
Right now my mind is set on a closed box with 3 x 6.5" front firing drivers, or perhaps quad 8" side firing in push-push config, 2 and 2 drivers facing away from each other. This PDF contains some inspiring designs: http://www.creativesound.ca/pdf/SDX7-sealed-pass1.pdf (Think 2x example 1 with dual SDK7)
What do you think about Tang Band W6-1139SI 6.5"? FS: 38 WAS: 11.78 Qts: 0.40 Qes: 0.47 http://www.tb-speaker.com/detail/1230_04/w6-1139si.htm as a driver?
So basically:
I need tips on what drivers that are suitable for such a small volume and small footprint box.
And I also need some tips on doing simulations. I've tried winISD but it won't work with Windows 7 or Ubuntu which I currently have installed. Any other programs that will do the trick?
Any help is greatly appreciated!
- Fredrik, Oslo
Old 25th August 2010, 10:13 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
You are going to need some EQ, Linkwitz Transform for instance.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 25th August 2010, 10:32 PM   #3
Thanks for the reply, I understand som EQ will be necessary.
But I forgot to mention that the monitors are active, and these subs will be as well. So I can EQ them digitally through a DSP. (Either a stand alone or maybe an AMP with integrated DSP)
Do you have any tips for drivers that are suitable? I'm so unsure about what too look for in the Data sheet. I read that Q should be somewhere about 0.7, but the drivers I have found that are made for use in small boxes all are like 0.3-0.6.
I have so much to learn
Old 25th August 2010, 10:46 PM   #4
Did it Himself
Final box Q should be about 0.7. A driver with Qts that high will be quite poor. I'd look for low Fs and Qts 0.3-0.5. Look for big Xmax, high BL and low Le. That Tang Band seems an OK choice.
Old 28th August 2010, 08:59 PM   #5
zobsky is offline zobsky  India
zobsky's Avatar
So basically:
- Fredrik, Oslo
A while ago, I designed and built something like this (though it was a reflex) as a proof of concept (push - push double bass reflex sub with an extended bass shelf type tuning), using these drivers SOLD OUT!! Bravox WFR-06BV-04B 6-1/2" Poly Cone Shielded Sub | Parts-Express.com .. Worked well, but due to what I perceive as a lack of snake oil lubrication, no one else ever built this.
Techtalk at Parts-Express.com - View Single Post - Another buyout sub
WinISD Pro will work with Win 7
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 29th August 2010, 06:01 AM   #6
Cokewithlime is offline Cokewithlime  Canada
Hi Fredrik - The Tang Band W6-1139 divers are an excellent choice for this application. I recently(a few months back) built some secondary subs for my HT setup. In each of the small (33l) enclosures I used 2x of the Tang Band W6-1139 drivers in a ported EBS alignment. Each of the subs are driven with their own 100W amp with a internal 20Hz HP filter to control excess cone excursion. They produce about 106db each with a F3 of about 33Hz.
Subjectively they are very musical but also respond quickly(punch) and blend very well with my existing system. They are not however equivalent to what one thinks of in a typical HT sub which is supposed to shake the pictures off the wall - lol
If you want further details of this build let me know and I can post them or PM you.
Small footprint SUB using multiple small driversHide this!Advertise here!
Small footprint SUB using multiple small drivers FredrikC Subwoofers 0 25th August 2010 09:12 PM
Multiple small drivers for large output? diarav Multi-Way 15 29th October 2006 09:39 AM
Large Driver or Multiple Small Drivers ??? emailtim Subwoofers 8 25th March 2006 11:02 PM
First time horn help.. small footprint Matt@Nearfield Multi-Way 2 17th May 2005 03:55 PM
