diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   34hz Horn (http://www.diyaudio.com/forums/subwoofers/172501-34hz-horn.html)
CuttaBoi 25th August 2010 09:57 AM
34hz Horn
Has anybody got any more info on this horn
http://srforums.prosoundweb.com/index.php/fa/668/0/
found in this topic
PSW Sound Reinforcement Forums: LAB Subwoofer => BillFitzmaurice DIY15" alleged to compete with Lab Sub????
Cheers
djn 25th August 2010 05:03 PM
The link does not work
voltcontrol 25th August 2010 05:13 PM
(First link doesn't work indeed) What do you want to achieve?
GM 25th August 2010 05:28 PM
Hmm, works for me. Anyway, it's a side view drawing of this picture which I assume is BF's Tuba 30.
GM
CuttaBoi 26th August 2010 01:01 AM
Originally Posted by voltcontrol (http://www.diyaudio.com/forums/subwoofers/172501-34hz-horn-post2283476.html#post2283476)
I'm looking for an efficient design (tapped/folded horn) that will get to 30HZ -/+ for pro audio use, and can be built on a budget..
Labhorn - complex & expensive
Jbells tapped horns (possibility) would ideally like to go lower though
BFM cabs, would like a flatter responce than what they offer
Scoops (Only suitable for certain genres)
Any suggestions much appreciated :)
kornnylike 26th August 2010 01:17 AM
Originally Posted by CuttaBoi (http://www.diyaudio.com/forums/subwoofers/172501-34hz-horn-post2283920.html#post2283920)
Check out my ciare 18 folded horn that soho design for me.
jbell 26th August 2010 01:24 AM
The big cabinet would do it with a slight alteration. The bigger S1, the lower it plays. 800cm s1 / 2800cm s4 would do it, but as you go lower, you end up overall xmax limited at a lower voltage. (800cm s1 is safe xmax from 30hz on up at 250 watts/44volts.) In .5pi its also flat to 30hz.
CuttaBoi 26th August 2010 01:38 AM
Hi Jbell, what would be the 1w/1m average & Max spl be for that, and mutlple cabs?
Do you know of any other drivers that mite be better suited?
Thanks for the help.
jbell 26th August 2010 12:22 PM
Originally Posted by CuttaBoi (http://www.diyaudio.com/forums/subwoofers/172501-34hz-horn-post2283940.html#post2283940)
Hornresp
http://www.diyaudio.com/forums/subwo...ml#post1598913
jrenkin 26th August 2010 12:41 PM
Originally Posted by kornnylike (http://www.diyaudio.com/forums/subwoofers/172501-34hz-horn-post2283933.html#post2283933)
do you have a link?
Resources saved on this page: MySQL 18.75%
