Th spud
Th spud
Old 13th December 2010, 12:29 AM   #21
Rudy81 is offline Rudy81  United States
Rudy81's Avatar
Complete pattern waiting for a job to do
Old 13th December 2010, 05:27 PM   #22
Rudy81's Avatar
I think its back to the drawing board on this project before I cut up some BB. I started thinking last night about the signal path length of that type of horn and realized this may not work so well in my room. Right now all my signals are time aligned either by speaker, like my mains and center, or in all the speakers in the 7.1 layout with Audyssey.
I don't know how long the path is on the TH, but it is way longer than any speaker I have. That could throw a wrench in my setup timing. I may have to re-evaluate and go back to looking at a ported enclosure to better match my mains.
Arghhhh!
Old 14th December 2010, 02:06 AM   #23
blamus is online now blamus  United States
sounds like u are nearly there. I say finish it, hook it up, and see if u like it. If you don't, give it to a friend for Xmas or sell it.
Also it sounds like u do have TA capabilities, so just add the path length to the TA.
Old 14th December 2010, 02:17 AM   #24
Rudy81's Avatar
True. I can manipulate the TA with my crossovers. I will have to study things a bit before finally deciding which way to go. Right now, approaching Christmas, I'll be busy anyway. That should give me some time to research the issues.
Old 14th December 2010, 02:40 AM   #25
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
If you have DCX then you can auto align. You can easily have 8m of delay equivalent with sealed subs under the mains. An extra metre is no big deal. If you follow Tom's suggestion of a couch on top or some similar nearfield setup then that might help.
Old 24th December 2010, 06:31 AM   #26
mastadon is offline mastadon  United States
where is the building print for the spud dts10???? i have a bunch pix but no schematic???
Old 24th December 2010, 08:43 AM   #27
Brett is offline Brett
Brett's Avatar
There is no general release construction diagram available for it. It was released for a limited time as a kit, but that option has ceased. You will have to work it out for yourself, but the driver specs were never made available, so you really have no chance.
Old 24th December 2010, 01:02 PM   #28
JLH is offline JLH  United States
JLH's Avatar
I've had this TH-SPUD design for a while. I have not got around to building it, but it should work really well.
Rgs, JLH
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 25th December 2010, 09:48 PM   #29
bigmouthindc is offline bigmouthindc  United States
if you google "th spud clone" there is a thread for the older dual 8 inch spud, it contains a diagram with measurements.
Old 27th December 2010, 02:41 AM   #30
Rudy81's Avatar
After much thought and some research I decided this project was worthwhile. Worst case I lose some time and 5 sheets of BB. It turns out the template for making interior dadoes (sp?) was a life saver. It made the project go much faster and made a huge difference when putting things together. This would definitely have been a major pain without exactly matching the top and bottom large pieces.
Here is a picture showing the dadoes cut into one of the panels. Prior to starting with the router, I designated a 'master corner' on each panel so that they would match exactly at the time of construction.
I want to thank jblauvelt for his initial post and his great ideas on how to make this build as easy as possible. The OP seems to suggest that the build took a weekend. Wow, that is super fast. I have been working on this on and off for two weeks. Of course, I'm just a novice woodworker and it was a learning process at times.
Th spudHide this!Advertise here!
Simple Spud booangler Tubelab 7 25th December 2010 02:27 AM
First layout with spud singh santa Tubes / Valves 0 7th March 2010 11:13 AM
Spud issues - a little help, please tomchr Tubes / Valves 11 13th January 2010 04:10 PM
Spud anyone? Tubelab_com Tubes / Valves 88 12th January 2010 12:22 AM
Pentode spud...? Fuling Tubes / Valves 3 29th January 2005 07:26 AM
