Old 14th August 2010, 11:29 PM   #1
Default tapped transmission line thingo, PVC pipe, will it work?
Trying to get the most from some 4inch woofers in a small hatchback.
the resonant frequency of the car is 51Hz.
so, can I make a 51Hz transmission line, with the front exiting at the rear, so, its a loop of PVC pipe, with the two ends meeting about 2.5cm from each other... if that makes sense.
I'll draw up a diagram of what I mean in a minute.
Old 15th August 2010, 10:59 AM   #2
Volenti is offline Volenti  Australia
1. I wouldn't have the 2 openings firing at each other with such a small gap, it will change the response, if you must do it that way, make the gap at least the diameter of the pipe wide.
2.TL/horns ect will drop in frequency when loaded in a vehicle, some of my really big TL's peak 10hz lower in the car than they do outside, so you'll have to keep that in mind.
Old 15th August 2010, 11:12 AM   #3
the 2cm gap means the area of the opening is the same as the area of the pipe.
folded horns that I've tried in the car will normally peak at the vehicles resonant frequency, assuming they play low enough
Old 19th August 2010, 11:26 PM   #4
I tried this out using some cheapo crappy stock 4inch speakers...
well, it made noise, not as loud as expected, and the woofer fried in about 5 seconds...
so, I'm really not sure if I got the gain I was expecting or not, and I'm guessing the 10 watt speaker didn't like 50+watts...
has anyone played with tapped horns much in car?
Old 20th August 2010, 12:57 AM   #5
and now I've just realised I had the high pass filter set at 80Hz while trying to play 51hz.. not that it would have made much difference as the woofer smoked anyway
Old, old, PVC pipe design... Ronmeister Multi-Way 6 5th June 2009 11:55 PM
Tapped Horn or Transmission Line mrevie Subwoofers 4 17th May 2009 07:38 PM
Tapering a transmission line...with styrofoam? Would it work? Spasticteapot Multi-Way 4 1st November 2006 07:21 PM
Telescopic PVC exhaust pipe bass transmission lines? VvvvvV Multi-Way 5 5th August 2004 06:57 AM
8" Quartz pipe for Transmission Line speaker MRehorst Swap Meet 0 26th December 2002 11:00 PM
Page generated in 0.07699 seconds (74.69% PHP - 25.31% MySQL) with 10 queries
