#11 |
#12 | |
I also measured using arcs around the corners, and present that in the spreadsheet as L'. I've also included the srqt method in the spreadsheet. Interestingly enough, the answer it gives is usually within a few mm of the centerline method. |
#13 | |
Here is a picture with a bend made up of three 25cm squares, and the lengths derived from the most popular methods, and my own in the middle. ![]() ![]() The Square-root method comes in at 70.71. Try running this through your program to see what it comes up with. Last edited by soho54; 12th August 2010 at 08:22 PM. |
#14 | |
I'll adjust the spreadsheet to reflect the correct net volume of the box. "balance" is the difference in height between the front and back of the box, using the calculated values for the folded horn's dimensions in the box. For the box to actually be a box, it should be zero. This is where Excel's "Goal Seek" function comes in handy .
#15 |
Mark Kravchenko --- www.kravchenko-audio.com
Hi Brian
Home early from work with a tummy ache. But a whole lot oh gingerale and I'm getting better. Been playing with the spreadsheet. Boy am I stupid. It finally dawned on me that the thickness of the material is in cm not mm. Now the folds make sense. Still have not quite figured out the goal seek function. I found it but hell if I know how to make it work. But fiddle with the box sizes enough and I get pretty close to the desired sizes. I have to say cool. And I have to agree that from a viewpoint of your math skills the descrepancy you described earlier is significant. A real life box rarely measures as modeled. It is always close. But I'm guessing you want to get as close as is posible. Mark
Mark |
#16 |
Did you ever throw your TH model into AkAback to see if the p or c constants used in HR were the reason for your 3Hz measurement difference?
#17 |
I have been reading the thread. As Brian pointed out the method of measureing down the middle of the bends is one of the most accurate means of determining horn path length when it is folded. That is what I have used for years.
I tried a front loaded horn that is obviously tappered. I can't get the crazy thing to behave. My deviation from error is small but it don't look like a horn to me! I even used the as built sizes. I'll check what I did again and see if there are any obvious mistakes. I have a couple of ideas for labeling the cells so it is a bit easier to Mark Mark
Mark |
#18 |
#19 |
From David McBean he is actually gone past AkaBak in computaional accuracy. His programis just a bit more limited. I can attest to it's acuracy as can Brian. It is really close to what you will measure in the real world if you actually make the box well.
Mark
Mark |
#20 | |
Once I can work out other foldings, I'll include them in the spreadsheet. |
| Folded horn length | Don Snyder | Subwoofers | 3 | 1st May 2009 11:14 PM |
| how to go from horn response to a folded bass horn design? | paulspencer | Subwoofers | 8 | 4th November 2005 10:44 PM |
| Looking For Folded Horn Sub Plans | nniwelt | Subwoofers | 16 | 29th August 2005 04:43 AM |
| Folded horn for Tannoy? | panos29 | Multi-Way | 12 | 17th October 2003 08:59 AM |
