Enclosure for B&C 15pzb100 Enclosure for B&C 15pzb100 - diyAudio
Old 10th August 2010, 04:04 PM   #1
bobekucor is offline bobekucor  Croatia
Default Enclosure for B&C 15pzb100
Hi, I need some help. I just got this speaker, and it seems to have great features for building PA or bass guitar box. What I want is, multi functional bass box, mostly for bass guitar ( matched with my 2*10 or 4*10 cabs), or to use as PA Sub in small gigs. Due to that I would like to keep the weight an size as small as possible, and it doesn't have to go to much under 40Hz, just need it to play nice
Is it ok to make the box with data from this diagram, or I can get same features with even smaller enclosure?
however, 105 litres (~4,2 cub feet) seems to be already to small) but, I am not an expert.
btw I ordered 18mm plywood (0,708") already
thanks,
Slobodan
Old 14th August 2010, 02:30 PM   #2
tb46 is offline tb46  United States
Hi bobekucor,
Looks like you could even reduce the volume from the manufacturer's suggested enclosure, and still get to 40Hz. Play around with the volume and port values in Hornresp.
Oliver
Old 16th August 2010, 10:44 AM   #3
thanks tb46, this will help
Slobodan
Old 16th August 2010, 01:16 PM   #4
You're welcome, let us know how it goes.
Oliver
Enclosure for B&C 15pzb100Hide this!Advertise here!
Ideal BLHorn type enclosure? (for Fostex FE168E∑ besides the recommended one) Fosta Full Range 12 20th September 2009 05:05 PM
Newb w/a Bash 500S needs sugg. on Sub & Enclosure deetz Subwoofers 6 12th October 2007 10:29 PM
Quick question re: finishing up my sub enclosure & mounting driver CUclimber Multi-Way 1 18th April 2004 06:46 AM
Recommendation of 2 cu. ft. enclosure for Titanic 12" MKIII and Rythmik 350W Amp AVaholic Subwoofers 0 15th January 2004 06:48 PM
Copyright ©1999-2017 diyAudio
