Old 10th August 2010, 03:23 AM   #1
Default Recommend enclosure for ED 13Ov.2 Subwoofer
I was given this driver by a friend, is it a good subwoofer?
Would it be suitable for a tapped horn or transmission line loading?
Thanks a lot!
Qts: .28
Qes: .30
Qms: 3.3
Fs: 21.00Hz
Re: 8.3
Vas: 176L
Mms: 195.0g
Bl: 21.70T*m
SPL: 89.1dB
Sd: 545cm²
Xmax: 18.3mm
Voice Coil: 62.5mm
Magnet Width: 6.750"
Cutout Diameter: 11.000"
Mounting Depth: 6.600"
Weight: 25lb
Total Height: 7.600"
Displacement: .07 ft³
Outside Diameter: 12.375"
Old 10th August 2010, 03:34 AM   #2
I had the opportunity to measure the t/s parameters of a 13Ov.2 about two years ago, using a WT3. t/s specs were nothing like the published ones. They were as follows:
Re: 7.256 (coils in series)
Fs: 28.3 Hz
Qts: 0.456
Qes: 0.496
Qms: 5.697
Le: 3.454 mH
I suggest getting the specs for your driver measured (or measure them yourself - see my site for a means to do this) before committing to anything like a transmission line or tapped horn.
Old 10th August 2010, 03:55 AM   #3
Thanks Brian!
Bummer. So did you build an enclosure for the driver? Any chance you recall what might be a suitable alignment?
Old 10th August 2010, 04:14 AM   #4
Originally Posted by rhapsodee View Post
Thanks Brian!
I didn't build an enclosure for it. I was just checking the parameters for the owner. FWIW, the t/s params for my eD 13Kv.2 were also off.
Old 10th August 2010, 08:08 PM   #5
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Using the T/S parameters from Brian...running the numbers makes for a driver NOT suited to a TL nor a vented alignment.
However it would run quite well at 4.425513017 cubic feet, sealed. Qtc = .707
__________________________________________________ ______Rick...
Old 11th August 2010, 10:33 AM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Richard Ellis View Post
...running the numbers makes for a driver NOT suited to a TL nor a vented alignment...
Don't agree, As I found this driver suitable for a T-TQWT, thus a ported or a TL should work too:
b
Old 12th August 2010, 04:16 AM   #7
I thought a driver should have a higher Qms to do front loaded designs...
No fair having a SIM program to do all the number crunching!
__________________________________________________ _Rick.......
Old 12th August 2010, 04:19 AM   #8
Just repeating my suggestion. You might end up with disappointing results if you build a sub based on either the published specs (or my measurements) and it turns out that your driver isn't a close match for either.
At the very least, measure Fs, to see if it's closer to 21 Hz or 28 Hz.
Please recommend a 10" subwoofer okmat Subwoofers 18 7th May 2010 10:18 PM
eD 18" subwoofer - 19Ov.2 - $185 shipped - Austin Texas CZ Eddie Swap Meet 6 14th March 2009 10:51 PM
Please recommend Subwoofer Driver mart34 Subwoofers 5 25th September 2008 11:07 PM
recommend subwoofer for stereo & AV use ycliew Subwoofers 1 24th May 2006 05:23 PM
Please recommend enclosure for this woofer Cro maniac Multi-Way 3 4th August 2004 12:22 PM
Page generated in 0.09532 seconds (76.40% PHP - 23.60% MySQL) with 11 queries
