List of drivers known to work well in TH
Old 8th August 2010, 11:50 PM   #1
TundraLTD is offline TundraLTD  United States
TundraLTD's Avatar
Default List of drivers known to work well in TH
Thought it might be nice to start a list of drivers that people know to have worked well. I want to start an excel spreadsheet to average things out and maybe be able to narrow down what attributes to look for.
So I've you've successfully made a nice TH what driver(s) have you used?
Old 9th August 2010, 01:41 AM   #2
Oklahoma Wolf is offline Oklahoma Wolf  Canada
Stuff I've used:
Tang Band W8Q-1071B
Stuff that has modeled fairly well for me (some will be better than others in a TH):
AE TD12H
B&C 21SW152
Beyma XMAX-12
Ciare 18.00SW
CSS SDX10
CSS SDX7
Dayton DVC385-88
Dayton QT210-4
Dayton RSS390HF-4
DIYMA R-12
ED 13AV.2
Eminence HL10C
Exodus Anarchy
Exodus Shiva-X
Fi BTLD12 D2
Hi-Vi SP10
Hifonics Atlas 12
Hifonics B10D4, B12D4
Hifonics BRZ15D4
Hifonics OLM1612
Kicker CompVR 10CVR102
Mach 5 MLI-65
Rockford Fosgate P3D210
P Audio SD21
RE Audio XXX 12"
Silver Flute W14RC25-S-04
Smith-Larson CS84SV
Tang Band W69-1042M
Tang Band W46-1316SM
Tang Band W5-1138SM
Tang Band W5-876SD
Tang Band W6-1139SC/SG/SI
Tang Band W8-1722
Tang Band W8-1747
Tang Band W8-740P/Q
TC Sounds Axis 12
TC Sounds Epic 10
That's all I have on this rig - the other computer has a long list too. Several TB 10" and up woofers model well too. I left out others that model sorta well but end up way too big, like the Mach 5 IXL 18.2.2 and Exodus Maelstrom woofers. The P Audio woofer comes close to that as well.
The Ciare looks to make a fantastic pro audio TH. The Hifonics woofers are all poly coned - not sure they're cut out for the stress on the cone.
Old 9th August 2010, 02:16 AM   #3
Brian Steele is offline Brian Steele  Grenada
Originally Posted by Oklahoma Wolf View Post
Stuff I've used:
Tang Band W8Q-1071B
Published specs or measured specs?
I think it's very important to distinguish between the two. My personal experience with one or two of the brands in your list suggests that some caution is required before assuming that the published specs are anywhere near correct.
Old 9th August 2010, 02:50 AM   #4
Published... I don't have the ability to measure woofers. Or afford most of that list
Old 9th August 2010, 05:16 AM   #5
TundraLTD's Avatar
I appreciate the post but I'd like to keep it to drivers that have been successfully used and measured like the B&C 15TBX100 etc. I just completed a 30Hz TH somewhat similar to the one Volvotreter has on the site. For a 6.5 it really blew me away, doing blind tests on friends (1/4 and 1/8th space loaded) they swear I have the dual 15 cab on. It's hard for them to accept that a 6.5 can make crazy intense LF like this
I have not had a chance to measure it yet but I used the Tang Band W6-1139SI and it works well from what my ears tell me with only a slight cab resonance to calm
next up I'm doing two 15TBX100 TH boxes to add to my PA, my design models very well in Akabak so time to build
Old 9th August 2010, 06:14 AM   #6
Ok... the thread title left it a little ambiguous for me. I just listed the ones I'm convinced I could get to work
That said, many of the drivers I listed have been successfully used and measured by others. That's how I knew of them to begin with. The B&C 21" as well the Exodus Anarchy and Shiva are examples.
Old 11th August 2010, 08:59 AM   #7
dangus is offline dangus  Canada
So, what attributes inspired you to model those particular drivers?
Old 11th August 2010, 03:00 PM   #8
TundraLTD's Avatar
I think Tom Danley and his crew may be the only people that know exactly what to look for for a certain design. That's why I thought it would be nice to try and see what people have used. The variables are many, and from goofing around with hornresp it would seem that a driver that may seem unsuitable for a TH design are great in a TQWP, but if you model 2 of that same driver in a TH the design works. It also varies by the bandwidth you are trying to produce. Lots and lots of variables
I think everyone is still trying to find drivers that work OR they have a few they know work and stick with them
Old 11th August 2010, 03:05 PM   #9
Low Vas and higher than usual Fs. There's more to it than that, but I find this is a good starting point.
Old 12th August 2010, 10:13 AM   #10
martinsson is offline martinsson  Sweden
It would be intresting to see what you have come up with, i have also designed and built me a pair of 15TBX100 loaded TH's, they are very compact and can be found here :
Martinsson`s Blog - high end low end - diy notes
good luck, they are killer dirivers !
As for what makes a driver suitalbe for TH applicaton, well one thing to consider is to have a TH tuning that is approx 10Hz above the Fs of the driver in question, in some rare cases a Fs equal to the tuning can be accepatble, but what makes this work in only some cases is beyond me, the 15TBX100 is one such dirver.
List of drivers known to work well in THHide this!Advertise here!
Audax drivers for sale: updated list Matt D Swap Meet 28 14th October 2011 10:01 PM
full range drivers in a sonus faber style cabinet. would this work? blrh93 Full Range 17 16th January 2011 01:25 AM
Wish List Speedskater Forum Problems 8 17th September 2009 11:06 PM
How do you measure drivers, what works/doesn't work pjpoes Multi-Way 5 20th July 2008 05:45 AM
dac list GŁnter H. Digital Source 1 11th September 2003 02:30 AM
Copyright ©1999-2017 diyAudio
