Help me remove a dual-gang pot out of the circuit!! Help me remove a dual-gang pot out of the circuit!! - diyAudio
Old 7th August 2010, 10:32 AM   #1
maglian is offline maglian
Default Help me remove a dual-gang pot out of the circuit!!
I got a Creative SBS 2.1 370 Desktop Speakers. Recently, one speaker stopped working or is very feeble. The other one is very good, works fine I mean. I'm sure that the POTENTIOMETER is faulty and causing all the problems. So I need to remove it, not replace. I don't need the volume control or the On/Off switch too (They are on the same board). Please tell me which wires need to be interconnected. I'm posting the pictures of the circuit, terminals, connector and the POT.
Picture 1 - View of the POT & the On/Off Switch
Picture 2 - Reverse side of the same board.
Picture 3 - The connector
Picture 4 - The cable with the RED marker is the output line. It has 3 wires(green,blue,yellow) + a portion of the Black wire. The other cable is the Input line, with 2 wires (red, white) + a portion of the black wire.
When connected to the socket, the green wire ends at the top of the board followed by white,red,blue yellow& black.
Find the pictures here
ImageShack Album - 4 images
Old 7th August 2010, 12:02 PM   #2
Bump!!
Old 9th August 2010, 01:54 PM   #3
epa is offline epa  Netherlands
Originally Posted by maglian View Post
Bump!!
i,am not an electrician,but here is what i would do.
first ,set de pot to the disered output,then desolder the pot whitout turning it.
then measure the resistance between each connection of the pot.
then simply solder resistors in place.
as for the on/of swich ,just bridge it in the on poss.(wire the legs together.)
Old 17th December 2011, 12:25 AM   #4
hew128 is offline hew128  Singapore
Am experiencing similar problems with the same unit. Are you able to share the final resolution to the issue?
Thanks!
Old 17th December 2011, 03:45 PM   #5
diyAudio Member RIP
To remove a pot you generally simply remove it and connect the
wiper point to the end of the pot point representing full volume.
rgds, sreten.
Help me remove a dual-gang pot out of the circuit!!Hide this!Advertise here!
Dual gang pot burbeck Parts 5 30th October 2007 09:49 PM
Dual pot in a mono gain circuit Netlist Solid State 2 8th October 2007 05:15 PM
dual gang slide pot supplier (uk) advice synergy Parts 8 1st November 2006 11:42 AM
Suitable dual gang pot for NIGC LM3875? findog Chip Amps 50 19th April 2005 09:23 AM
Copyright ©1999-2017 diyAudio
